Masco C-10 Mic/Phono Amp
I have an old Masco C-10 Amp I was trying to get going. I've tried reforming the caps and I've replaced the burnt tubes (specifically the twin diode rectifier tube). I was getting a good output but the transformer was heating up. So I then replaced the multi-cap can with some individual capacitors. Still heating up. I then drew out the schematic and noticed the 20k ceramic resistor going to ground. I had a look and it's on a two terminal block bolted to the chasis and the terminal has been busted off. It is now held in place with a wire to the adjacent terminal. It looks like to me this shouldn't be going to ground. Maybe someone with more knowlege than I can have a look at this circuit and tell me what they think.
Thanks,
Craig
Thanks,
Craig
The 20K as shown would pull a lot of current that's why the transformer is heating up, a more reasonable schematic is shown below, perhaps the 20K is sub'd for the choke?
Jaz
Ya, that's what I've assumed. I was thinking it should go from the cathode of the rectifier to the 40uf cap then ground. I tried that, but have less volume output and still a heating transformer.
What about like this?
Jaz
Right now, the center tap from the B+ transformer is going to chasis ground. Also it's using a multi-cap can, so no way to grab the negative of the 10uf/20uf cap. Do you think the center tap should be going to this resistor?
The 20k is a bleeder for safety, assuming the scheme in post#1 is accurate. It drains the dc after turning off. You can use a larger value if you are concerned it's pulling too much current. I'm actually using a 1meg on an amp but that's overly "slow."
