My C3G spud headphone amplifier is finally finished and playing music.
- C3G triode wired running at 145V / 15mA
- Cathode bias with tightly matched Morganite resistors and BG N bypass caps
- (yes, there is still people preferring a conventional setup over LED bias, but only when Black Gates are used)
- Salas SSHV2 with LC prefilter
- DC heaters
- Lundahl LL1689 wired 18:1
- custom wound toroid mounted on top
- all the guts underneath
Absolutely dead silent (Pitch Black background...😉 ).
I just discover your Kunstwerk!
What headphones do you use?
What headphones do you use? 300 Ohm?
Jpak, blackdod, for this one I am mostly using Senn HD800. Tube amplifiers with output transformers are better off with high impedance cans because of the availability of suitable transformers... --> see other thread on Diyaudio 😉
The Lundahl perform very satisfying... very well worth the money.
I see you have reached your maturity as a amp builder, Stixx. Not much room for improvement now.
Dang, life will be getting boring then... 😀
Hvala ti!
Ok, Thanks!!! 😉
I´m looking a new tube Amp for my Senn/Beyer (300/600 Ohm) but yours Amps have very good look. 😉 😉
Cheers
Good job.My C3G spud headphone amplifier is finally finished and playing music.
- DC heaters
I found one error
Supply protective conductor is connected directly to ground. It should be the resistor 10-100 ohm. This prevents the creation of ground loops.
Snub the resistor with a cap too. I'm guessing 0.1uf poly.Good job.
I found one error
Originally Posted by RK1
Good job.
I found one error
Guys, I am at a loss. What is meant with conductor... the choke? This one is not conncted to ground, nor are any capacitors in the regulators... Clue me up please!
I think he is referring to safety ground.
Lifting that with a resistor (no matter what value) would violate all German electrical safety laws.
I can see only a single point where all the ground wires connect to the chassis - this is exactly how I do it, too. No problems with ground loops.
You could connect signal ground via a resistor with safety/chassis ground, but why if its dead silent? Don't fix it if it ain't broken...
Seeing the level of construction skills, I guess Stixx knows EXACTLY what he is doing.
Great piece of art BTW.
Martin
Martin
Martin
Probably you do not understand (or my englsh is bad 🙂 )
My opinion has nothing to do with safety.
-> Casing (chassis), especially metal, it must be connected to the protective power (no resistor).
-> ElectricMass of the (mass supply) should be connected through a resistor to the protective power.
Have a nice day
This is my new Tube preamplifier .
3 tubes ( two PCF200 and one EF183 ) on each channel , -3dB at 400KHz , gain 19.4dB .
Very nice!
Where did you get 10-pin sockets?
my new preamplifier, still on construction but nearly finished:
She will definitely love it! 😉
- DC heaters
Peace of art! Now wait for similar designs on the market. 😉
Would you mind pointing me to the other thread?
It is worth repeating Stixx produce it your self before the PRC copies you. RegardsPeace of art! Now wait for similar designs on the market. 😉
Thanks Wavebourn! But man how would I hate that... 😡Peace of art! Now wait for similar designs on the market
Here you go --> http://www.diyaudio.com/forums/tubes-valves/228625-all-dht-set-headphone-amp.htmlWould you mind pointing me to the other thread?
Unfortunately I have absolutely no means of producing this... apart from a few extra cnc parts 😉It is worth repeating Stixx produce it your self before the PRC copies you
I swear last night that area was flat. Painting toroids can be tricky. Just saying.
It's alive.
- Tubes / Valves
- Photo Gallery
