Control pcb have remote (trigger) output and input too?
How is the possibility of remote control?
Can I use this remote? Apple Remote - Apple Store (U.S.)
this remote
Any and all information you can share about your DAC helps us make a decision. PCB size would help, as well as price without IV. Very very interesting 🙂
Well!I know this, I was discussing with manufacturers to reduce the number of DAC kit, I will soon complete information!
Thank you for waiting!
Nice design !
Will the tube output stage also be available as an option in the DAC kit ?
Danny
Danny
At this time we don't consider a pcb for the vacuum tube output stage but this is very very simple so you can mount it all on air using the four K&K Audio CCS modules.
Actually I use a solid state power supply on a pcb and this pcb can be created by Quanghao.
Nice design !
Danny
Greetings!
I will do everything so that you can enjoy the sound from this DAC.
however, the current is about as traditional Tet Vietnam, by which time work will begin on 1 January.
Thank you for your interest and wait.
You can stand open for me a group buy, because I can not do it-by the provisions of DIY.
a dac including:
1. Kit DAC
1 x kit controller and hand controller
price $ 450. a minimum of 20 sets.
Can this be supplied with an 8 channel output?
Hi!
may be i can make it, but the 2 Chanel is better!
thanks
8 channel DAC need a 8 channel digital input.
Amanero are working on a new USB-I2S module with 8 channel so we can start some test with this in the future.
In any case this is another project completely different.
Opened now a relative Group buy
http://www.diyaudio.com/forums/group-buys/228755-dac-end-r-es9018-full-assembled-board.html
I have an exa21 usb to i2s converter that feeds 8 channels of i2s. Will this work with your board? Can your board be configured for 8 channel balanced output?
The chip can output 8 channels. I wonder if it is possible to configure this board to allow that....
please see the post 153
thanks
The Opamp I/V on 6 ch BuffaloIII
Hi!
I wold like to use your OpAmp I/V amp for my 6 ch DAC (based on BuffaloIII from Twisted pear).
The output from this is;
4 ch with 4mA pp and
2 ch 8 mA.
What I/V resistor ? Is it OK with 40 ohm for the 4mA and 20 ohm for the 8mA? Can I adjust the gain from the OpAmp I/V stage if I want?
Best regards
we417
Hi!
2 ch 8 mA.
Best regards
we417
Hi!
2 ch 8 mA.
Best regards
we417
yes, now i use R I/V = 10R, you can change it if you like,
thanks
- Digital Source
- DAC-END R (ES9018)
