i'd say that there is an error but not quite sure. will check tomorrow,now it's late and i'm too tired to check again...
nice work although! 🙂
This Limiter circuit with low cut filter can be use with XLR circuit add on input.
good first time I participate in this forum and I like very much the contributions made by members are published amplifiers uy interesting here. as to limit post you posted resembles the limiter QSC USA 1310
regards😉
I have a little doubt with amplifier vertex posted sesitivity the part where it says that there is going to be located there or want to build this amp and I know that doubt to carry out
I appreciate your help thanks and regards
om selamat pagi kirim schemanya ni mau coba yang vertex
Hendi, ini adalah forum berbahasa Inggris. Silahkan posting terjemahan bahasa Inggris juga jika Anda memposting di indonesia
Hi Apex audio. Can I change amp this to a 2 step version with 150v and 75v rails ? I have just got a 3.5kva transformer with 53v windings x 4. Can I just leave out the lower voltage stepper ? and do you think this will affect the efficiency much.
Thanks for all the work your have shared.
hello
Hi Alex. Good information, where I can download files in Sprint layout.
...... Hmmm very close to my PCB or vice versa 😱
Yes this is APEX vertex amp, i try to redraw this amp but i have little doubt on the drawing, if you have the schematic please share.
Hi wiljj78, is it possible for the 4 driver transistors(mje15034/35) in the middle to be fix in the main heatsink under the board?
regards,
mj777
regards,
mj777
- Vertex Amp By apexaudio
