I agree with the poster that talked about capability in the 100-500 hz range for metal. I have discovered my own system is weak in this area while messing around with a quick and dirty line level baffle step circuit. I could get the tonal balance dialed in just right but the mids were strained (Seas Excel W15's) at a moderate level. I also needed more gain overall. Those SEOS-12 designs do look interesting. I bet metal sounds great on something like that. If it were me, maybe that Faital Pro 12PR300 design in a sealed cab with a couple of good subs.
He knows what he's doing, a big power handling and SPL peak around the x/o frequency
of 400Hz by running the big bass unit high, and the big (for a mid) high as well, where they
effectively overlap you get high SPL with very low distortion. He is no mug, quite talented.
rgds, sreten.
rgds, sreten.
Well good luck with that, low B is inaudible on most hifi's, and impossible
live, why I switched back to standard E and dropped D for the E string.
Low A whist being 27.5Hz is pretty useless in most circumstances,
your only going to annoy a lot the bass player your ******* off.
Stepping on other peoples feet is not a good idea, unless its
unison stuff, if it it isn't, I for one wouldn't be interested.
rgds, sreten.
I am the bass player. Guitar territory I'm occasionally annoying.
Play a completely normal 4 string bass in D for most songs.
Drop tuned strings that aren't thick enough buzz on frets.
Or perhaps my bass just isn't of long enough gauge for D.
My knuckles swell from the clamping force after an hour.
Probably some arthritis action too...
For me, baritone guitar was an experiment in fatigue reduction.
Tuning AEADGB "the craw" was a further ergonomic consideration.
And octave drop, so I don't have to switch instruments mid song.
I could use the same stompbox to drop my bass rather than droptune,
but I get more versatility and extended knuckle life from the baritone.
Fair enough if you are always the bass end.
rgds, sreten.
Still, guitar players can't play bass, though they think they can 😉.
@ Andrew
What you say is probably true for the stage but in a home sized room a good 8 inch has plenty of kick and grunt.
This is why I made the suggestion of the Eminence midrange in post #8
@Sreten
my daughter plays bass
Yamaha jazz bass and a fretless 5 string
Making a box that would play well for the lower notes was hard work, needed a quad with 2 * 15s and a pair of 12s, this were too much trouble for her to lug around tho ( school band) and they got turned into my part subwoofer boxes later on, so I sort of understand your argument but I do think the "Tarkus" while a great design needs something a little different to meet the OPs requirements
@kenpeter
I know exactly what you are saying there about the finger problem, it is one of the things that keeps my D at the garage ban level for fun, she's only a little tacker and while her day job means she is strong ( gardener ) her fingers hurt after playing for more than an hour or two. I have the same problem as my job is a cook and chef
@Sreten
@kenpeter
Not sure what the OP would consider heavy metal, but I'd expect these to be somewhere near.
Avenged Sevenfold - Buried Alive - YouTube *
Slipknot - Left Behind - YouTube
*The start isn't particularly "heavy", but it gets going by the end. I rather like this track - a rather good test, IMHO, of the sheer oomph of a system. Also check out "Nightmare", by the same artist.
There's also the usual Marilyn Manson etc.
Chris
Like the first link, prefer this by the second artist much more:
Slipknot - Wait And Bleed (Animated Version) - YouTube
Then again, never really liked Slipknot.
I am more into prog rock/metal. Love Porcupine Tree/Opeth/Katatonia/Tool, etc...
But I don't diss, just have preferences like anyone else.
The the OP's questions it all comes down to the 80-(100)hz -> 800hz range. This is the core of HM. Yeah there is stuff outside of, but a good 15" midwoofer mated to a good HF transducer (say CD on SEOS wg or such) will work way better than 6" + 1" dome. Take Klipsch cornwall as an example. Not the best example and a bit harsh, but way more rockin than typical audiophile 6.5" two way.
Order the compression drivers and waveguides from diysoundgroup and get the eminence delta 12s local. You should be way under budget and have something that can jam. Shipping will be as much as a pair of the dna350 compression drivers. Figure 300 bux us for the drivers, waveguides, and shipping.
Hold the phone Guys !
Client has decided to go with the Eminence coaxs, either a 12" 2 way or a 10" plus sub.
Thanks all for your suggestions and the important information about metal's "Special Needs". I really appreciate all of your input.
Keep an eye out for the build pics when the project kicks off. (Which will be just after they finish putting up the new shed - I know, one damned thing after another...).
Kind Regards,
hotblakk desiato
Kind Regards,
hotblakk desiato
the original Karlson 15 or similar bulk K-coupler should do a nice job and reach over 120dB peaks without much cone excursion.
Beta 12LTA is pretty sensitive and will play "loud" but it lacks motor strength for transient reproduction
Karlson K12s are pretty good but of course do not go "deep" - but in some music that doesn't matter as many speakers just sound "thuddy"
1 cubic foot of front chamber "volume" does well in the little X15 size K-couplers. K15 and larger may use 2.2-2.7 cubic feet.
a slotted pipe Karlson waveguide with competent compression driver can sound very good.
a few of my toys
80 ounce magnet Eminence coax in 1960's K12
http://imageshack.us/a/img3/4994/jek4slitk12rear.jpg
109 ounce magnet version
http://img842.imageshack.us/img842/2091/monstercoaxrear.jpg
Carl's first X15 size coupler - - 28"x20"x15"
http://img227.imageshack.us/img227/687/x15atestbd9.jpg
a few of my toys
rgds, sreten.
Sreten-
While there is actually a dip at 400 in that plot, I've heard the original Tarkus- in a large room with lots of power on tap playing Deftones. Paul is a personal friend of mine and I agree that this project should do most metal just fine as Paul likes quite a bit of that genre. Granted- I did not get to hear them at normal levels, but at moderate to loud they did achieve ear-bleeding levels with some slam. I don't know what they do on other stuff at lower levels.
Winslow- You'd be surprised what metal has for instruments if you include all of the metal subgenres.
chris661- MM is more of a shock-rock/industrial act. I would not call his stuff metal. A7 isn't a bad example. Slipknot is borderline to me, kinda 'nu-metal' as they say, since they even go light on material at times.
I'm really simplifying this list below, as there are multiple genres I'm omitting.
A list for those that smash things (or the arena I call 'metal'):
Meshuggah
Becoming the Archetype
Metanoia
Paramaecium (doom style)
Horde
Poems of Shadows
Amon Amarth
Sympathy
Tortured Conscience
Antestor
...throw in some cyber/industrial:
Screams of Chaos
Brainchild/Circle of Dust
Fear Factory
...orchestral:
Sonata Arctica
Nightwish
...prog-metal:
Dream Theater (and many more)
...hardcore/extreme:
Norma Jean
Converge
Zao
Hatebreed
As I Lay Dying
Lamb of God
...and nu-metal (not typically as heavy):
Slipknot
Disturbed
Tool
Killswitch Engage
5-Finger Death Punch
Just a synopsis to make sure which direction we're heading here...
Later,
Wolf
what gets called metal seems to vary. None of the bands above are what i call metal, rather nu metal. Swings and roundabouts, i dont personally see why any specific aspects of design would be needed at all. Just my opinion.
.... a commission to build a pair of custom speakers for an old client (for his son, actually).
just a note
sorry blakkshepeaudio for off-topic talks 😀
Waves MaxxBass
u siad it man , but why they still think they can ? they grab the bass , play it as they play a guitar with a pick , and they still think they r playin bass .Still, guitar players can't play bass, though they think they can 😉.
I don think that s necessary , most of pa systems don go that low , and in today's music you don see that much earth shaking bass freqs , if you look at the equipments people use for rigs these days most of the times you only see a 4*10 cabinet for bass , and in big live situations the sound engineers use some processings to bring out bass (mostly first) harmonics to make it sound bigger and lower (there are even vst plugins that can do that) take a look at this :@Sreten
Waves MaxxBass
it s physically impossible , in drop tuning you go a whole tone below the first string standard note and the rest stays the same as standard , and if you go one octave above the standard you ll do some serious damage to your instrument and the strings will become so tight it will cut your fingers , if you tune your strings one octave lower the strings will hang and you will not be able to play , and there s no pick-up that can go low to around 15hz (standard b is 30hz)Not really. Drop B is one octave above the standard B of a 5 string bass guitar.
Nothing wrong with using a pick to play bass.
JJ Burnel, one of my favourite bass players, uses a pick.
The problem with guitarists playing bass is the mindset.
lol random generalisation. Plenty of guitarist play bass, myself included, and often manage just fine. At least in comparison to a bassist playing guitar...I wonder how these generalisations really apply to multi instrumentalists?
If the 10" Peerless in the Tarkus interests you, get its bigger brother, the 12". That's a real woofer! (said by a guy who usually prefers pro drivers).
Very interested to see how this project turns out.
Ken, try a G&L L2000 with Ernie Ball Cobalt Strings. From what I've tried so far, that's the only bass and strings that really do the low things with both authority and clarity. I'm using BEAD tuning -- on all my 4-strings -- and found my weapon with the L2000 (6-bolt, fat maple neck and FB) and doesn't stop to amaze me every time I pick it up...
On topic, monitoring the bass at home I occasionally do with my main system which is built around beyma 15XA38Nd pro coaxials and they do of course very well for the hardcore/metal/etc stuff I like to listen to (that's why I used them, building a Harley-Davidson soundwise, so to say).
Therefore, the Emminence coax system will be a good choice I would think.
The solution to keep string tension while using a dropped tuning is to use thicker gauge strings. I go 2.5 steps down and then another step on the low string when I want nasty through a Krank amp...well emulated amp.
latest Beyma coaxes with the bigger tweeter looks interesting
or at least the woofer part of it
the 12" coax with additional woofer in 2.5way 😀
- Speakers For Heavy Metal ? What Matters ?
