I do not know if the colors are right but the top resistor band colors read as follow:
blue yellow brown black brown red value = 641X1 tolerance 1 % temp=50ppm
bottom
brown black black brown brown red value = 100X10 tolerance 1% temp=50ppm
Please double check the colors.
bottom
Hi again.
Just in case you want to know how to read the resistors here it is a link that explain how to read resistors.
link:47 ohm Resistance Pack-1/4 Watt (10 Nos.) [TPS-00457] - Rs.4.00 : :+: www.onlineTPS.com - Electronics and Robotics Components Shop - India, Components at your Doorstep - Satisfaction Guaranteed
tauro,
Thank you for the #4 message, and #5 message is most welcomed. 🙂
BTW, upper is 681R, bottom one is 1K.
tauro,
That is correct.
- Design & Build
- Parts
- Help Me Identify a Roederstein MK3 Resistor
