What do you do to it to make it an omni? It's too bad that it doesn't do what you thought it would do. I still like it...
Well, I kinda knew this flooder wouldn't work out, so I made it a certain way to be able to add a row of acoustic reflector lenses. You'll see.
The problem is that there is no direct response from about 3kHz and up...only reflected.
No direct sound above 3kHz is a situation.
What exactly is the problem?
a side firing L and R flooder with C for direct cues, adjustable in volume and delay, in a single box would be an interesting concept. I.e. I like the idea better than Elias' single box stereo speaker. Of course that project may have changed.
What, put a row of drivers down the middle?
And sum right and left to center?
yea, but then you'd need more drivers.....
It would be like mini ambio without the extreme panning.
It may not work, who knows.
Norman
Well......it sounds like I'm in a sewer pipe!
I'm thinking direct sound should reach the ears first. Then reflected.
Norman
I'm sure it won't work. Although I was suprised on how much sound was coming from the sides. But it was only high frequencies so it sounded disjointed. A plus was that I was able to cut off RACE at around 1-2kHz 🙂
If I went with the matrixed center, that wouldn't help to push mid frequencies to the sides. I would still have to apply RACE and I'm not sure of the effect of that on a mono center....it may not hurt it. But the center still would not do much for the delay of HF coming from the sides.
Also, with the omni design.....it would alleviate CTC CF
Flip the front baffles around so the 45 deg is toed-in. 😀
Yes, it might just come to that 😛
Split it down the middle and go with traditional stereo set up.
I don't think line sources are good for critical listening anyhow.
Well I guess the difference would be the adjustable delay? Oh and this one has the side drivers at 45 degrees.
I'm sure Elias flooder is good. I think the problem with this is that it's a line source and it's nearly equally as loud coming off the wall because of the cylindrical wave front, add comb filtering to that and the fact that line sources swamp the room, and you have yourself a perfectly constructed sewer pipe!
perhaps im mistaken then. I thought Elias' speaker was just L and R. Either way I havent listened to or built his speaker. Just my impression looking in from outside, without having tried it 😀
you can always try the left speaker, summed left + right speaker, and right speaker.
Just use 3 drivers and play with levels, play with a squeek of delay.
Yes race won't be there, but it gives a solid center and a panned left/right, versus a diffuse center.
Norman
Norman
Look at the size of this bugger!
I have a new name for it. The "Ambiolith"
We have a monolith....we have a stereolith, we now have the...
AMBIOLITH...LITH...LITH...LITH
haha!
haha!
Looks like you've done an overly wide and tall stereolith without the tweeter 😀
You should have put a third line in the center and used the matrix 😉
- Elias
- Elias
- Elias
Yeah. I wanted to test the flooder theory first, to see if I would get good separation. I did, but only in the FR of about 3kHz and up, and to tell you the truth my heart was in an omni design in the first place because I knew there would be a mismatch between RACE and the reflected signal.
I will try the matrix theory with larger full ranger point source drivers. Maybe I will just clone yours and see how it sounds.
its impressive, but why did you make it black? why not white...it could have been less visible
Ever since I saw 2001 space odyssey, I wanted a monolith as a design statement! I'm not kidding about this 😀
Wrong, because perceptually the mid freqs are coming from the side if you'll use the matrix x=0.5.
This is one of the scenarios where traditional precedence effect breaks down.
See this simulation. Here the stereo signal is fully panned to the left side. Note the direct sound is much weaker than the sound reflected from the left wall. Reflection overrules the leaked direct sound, and stereo is enabled.
Elias Pekonen Home Page - FDTD simulations on Single Speaker Stereo SSS
- Elias
Yes exactly there is no way to steer the midrange freqs by only using 2 drivers. You'll need 3 drivers and the matrix. Then only a vector is formulated which can be steered by the stereo panning.
- Elias
- Full Range
- The Supernova! (a full range flooder line source)
