thanks to APEX and Jhon Bali for PCB design. AX14 I use Protect from B500. I prefer character AX14 for my home.
Nice work,
hi apex sir,
i finished ax20 with 4pair , supply voltage 50vdc, with 10 ohm 10w resistor with rail instead fuse ,when i adjust the 1k preset to clockwise maximum 200mv is showing ,
cant adjust to 2vdc any suggestions.
i try with 2pairs also but same thing.
Finally, your AX14 is now singing...Congratulation friend....
Thanks mas Arif 😀, thanks to APEX and friends all are willing to help in all
hi apex sir,
Increase resistor value from 1k to 1k5 in Vbe multiplayer from base to colector of BD139.
what is the bias current for AX-14
I am using 35-0-35VAC transfoermer
Set 15-20mV on 0R33/5W (about 50mA bias)
sir I have adjsd 60mA bias
hello sir plz share amp using 3773
Amp using 3773 you can find in thread: http://www.diyaudio.com/forums/solid-state/167394-quasi-amplifier-beginners.html
hello apex sir I have made stereo AX-14 and using with 35-0-35Vac / 250VA transformer.
in one board I am getting more sound and in another board I am getting low sound
what to do? sir. .
what to do? sir. .
compare voltages at working and non-working channel,when you find drastic diference take a closer look at nearby parts and their values. no one can help you from distance not knowing even close where you could have done a mistake. usually it is misplaced part,it's value or position...
D1 on D14 schematic reverted polarity! This is right polarity.
hello apex sir which will be good amp either AX-14 or D14 for 3 way tower speakers
oh.. that mistake is misplaced part that's it . .
hi apex sir, i am back,
i did what u suggest.( increase 1k to 1k5), now i can increase the bias voltage,
i set 10mv for emitter resistor, now perfectly working, (power , signal ,clip leds) perfectly working. i will post images when my camera back from my friend.
Can you post PCB and component layout?
- 100W Ultimate Fidelity Amplifier
