B&G RD-75 dipole - baffle and or waveguide?
I went all the way to Norway yesterday to listen to Stig Erik system. The only two things I can say it's that he is a really nice guy, and that his system is bloody great! It's much more impressive in reality than pictures.
I own the Orions, they still are great speakers, but this is something different.. Guys, buy a pair of RD-75 as soon as you can.. 😎
Hi Guys,
I just received my pair of RD75 planars from PE over the weekend, and I'm excited to start measuring, testing and building!
I have access to a large anechoic chamber and some very good measurement gear, so I plan to run a full gamut of tests on these to see how they measure up. I'm particularly interested in THD performance and characterizing the 5kHz resonance.
Although I'm very intrigued by the idea of a dipole implementation, my listening space really isn't going to work very well for that as I don't have any space between the loudspeakers and rear wall. As a result, I'll be building an enclosure that follows the suggestions in the white paper as closely as possible (10" deep, 6" wide, very well braced and damped).
Has anyone here tried a sealed enclosure? Any success or suggestion?
StigErik:
A while back in this thread or your other one, you mentioned that one of your two ribbons was buzzing, and that you were looking at returning it. After that, you never really mentioned it again.
Can I ask how you resolved the issue? One of my two ribbons is buzzing about 1/3 of the way down form the top at frequencies between 1 and 3 kHz. I was running 1kHz tones to see if I could get a rough frequency response in-room and noticed it right away. It's less noticeable with music, but it's still there.
Did your buzz go away with time, or did you exchange your driver? I checked the driver closely and don't see any signs of damage, but I did notice the foam in the rear outlets was a bit uneven. I carefully straightened it with some plastic tweezers, thinking maybe it was contacting the diaphragm, but it didn't help.
Any suggestions on this would be appreciated 🙂
I'll keep everyone posted on the results.
Owen
StigErik:
I did not return the drivers - too costly to ship them back and forth across the Atlantic.
I never really found the real source of the buzzing, but I discovered that applying pressure to the front waveguide stopped it. It seems that the buzzing has little to do with the ribbon itself, but rather a mechanical problem with the waveguide. Anyway - installing a clamp solved the problem....
I friend of mine who also has RD-75's solved it this way:
Hi Guys,
Owen
Wow, sounds fabulous! 😎
Hi Stig Erik, I am afraid I have to give up on the Rd-75, it's just too much risk for too much dosh.. But, I might well take the RD-40 instead.. Should work ok on top of two 18" crossed around 300hz?
One thing though that "bugs" me is the non constant source size depending on distance.. I know, I am asking too much! 🙄
With any line source you have to optimize frequency response and woofer integration (delay/distance) for a given listening distance.
A rather sexy solution with the RD-40 could be to use four 10" long-throw woofers, two below and two above the RD-40. The Seas L26ROY that Linkwitz use in Orion and LX521 would work very well.
Yep, thought about it too! The baffle would have to be strong though, these drivers are rather heavy.. and I can imagine some serious vibrations too. With the first option I could still hang the planars on the ceiling.
You can still hang the RD-40 below the upper woofer. My idea is:
Make two W-baffles like the Orion-3.4 with two 10" woofers, one baffle for the upper and one for the lower woofers. Use four slim poles between the two woofer baffles. Hang the RD-40 in the upper baffle. Simple!
I see! Will have to pass the UN (read my wife..) vote though.. 😛
Remember I don't have a dedicated room like yours..
I'm in the same boat as you lolo... my main system is in our main living space, which is why dipoles (and massive 18" H-frames) are just not going to be an option.
Thanks!!! I'll give this a try and see if it helps. I was also pondering filling the empty channel behind the waveguide with expanding sprayfoam. Having a hollow metal channel that length somehow seems to be asking for trouble. On the same note, I suppose an intelligent application of this stuff could be the ticket:
Sonic Barrier Lightweight Vinyl Sound Damping Sheet 27" x 40 268-035
I've used it on metal chassis before and it works wonders in terms of deadening resonance.
I also have one more question for StigErik:
If you were talking to someone who is used to equalized sealed boxes that have good output down to 30Hz, how would you describe the output capabilities of the 18"-21" H-frame arrangement?
I was very close to pulling the trigger on a quad of the Goldwood 18" drivers to build some H-frames (MJK style) just to see, but I can't imagine how you can get any SPL from such a system. You've only got a few mm of excursion, and they are painfully inefficient at lower frequencies.
Do you need 12 x 21" drivers like you have to get decent output, or would 4 x 18" work reasonably well?
I don't want to downgrade in terms of output and LF extension, but I would love to hear what everyone is on about with this dipole non-sense 🙂
Owen
StigErik,
I want to thank you for your posts here which I discovered within the last year and which prompted me to push ahead with my own RD-75 system. I bought the RD-75s used about 10 years ago but they had been sitting. I had planned a more involved frame to support the RD-75s but when I saw your hanging method, I thought, that looks easy, I can do that.
I used some 15" TC-Sounds Aluminum cone woofers which had been offered at a great discount some years ago to the dipole Yahoo list (if I remember right.) I am using a DBX Driverack PA for crossover and EQ. I am crossing over at 400Hz, LR24dB. I have a velodyne ULD-18 that I cross to at 50Hz. I could not be happier with how it sounds. I have yet to work on the room acoustics and surfaces so things are a bit rough looking in the pictures.
I have a more detailed write-up in a thread I started at http://www.htguide.com/forum/showthread.php4?p=564457#post564457
Greg
Hi Guys,
StigErik:
Owen
Did you do some measurements?
Hey Owen, really excited to see your measurements. I built a pair of GR Research Super Vs but am very curious about the dual RD-75 + open baffle sub method that StigErik is using. If I'm not mistaken, I thought I read that the foam baffle StigErik added to his RD-75's cut out the buzzing? Can't remember, will let him chime in on that one. Do post your results on this!
@gworrel, that's an awesome looking setup! Looks like you might be getting a little diffraction from the RD75's being placed a little behind the woofer towers? Thoughts?
I added the foam baffle to round off the edges and reduce diffraction. It did not affect the buzzing.
I did add a clamp between the front and rear side of the driver at the point where the buzzing came from. This solved it, and over time the buzzing got away, and I removed the clamp. I have no answer to what was the the exact source of the buzz and why it want away.
