Don't feel too bad, I've never had any luck understanding HR at all. I can learn most software, but HR just doesn't not compute for me.
Someday I hope to get someone to tutor me in its arcane ways.
Mrs JRKO had a glass of wine I had..........more. In my defence we were watching Hitch
Thanks Pano. I got winisd straight away but I kind of feel like I'm playing (or failing to play) a text based computer game of days gone by with HR😱 It doesn't help that I don't understand all the workings behind it.
Can anyone help with the flare rate & measurements of the 1005 based on the info Pano & GM have given?
I hope to maybe start 'mache madness' on Monday all being well
There is certainly a learning curve involved.... have you seen this tutorial?
hornresp for dummies
There is a lot to it, but once you get the basics it's not too bad.
I'm quite curious what you come up with. I just got a pair of used Radian drivers in the mail. I was planning on having my father-in-law turn me some round horns, but this thread has me thinking about building some mulitcell horns....
Best of Luck!
Best of Luck!
If there's any chance you want to go for the same cells as an 1803 I could give all measures at whatever intervals you wanted and do it as early as tomorrow. If so do you want them in inches or cms?
😱 !!!Cal & Pano to the rescue!!! 😱
THANKS GUYS
Can I be greedy and ask for both in centimetre increments please? As it only paper I might get away with both 😉
There seems to be some interest in this brilliant, low cost idea of Pano's so the more the merrier me thinks!
THANKS GUYS
OK, I'll have to dig out the tape measure with cm markings. I greatly prefer metric, but live in a country were it is considered an evil foreign plot. ;(
(I feel that fractions are an evil plot to confuse me)
...but live in a country were it is considered an evil foreign plot. ;(
Metric is the thin edge of the wedge. Wait until your banana's have to be straight, it's illigal to sell in lbs so greengrocers get fines for giving little old ladies half a lb of grapes 🙄 Its all madness, pure madness
Fractions however are the devils work and especially fiendish when they are of inches like 3"3/16
Ahhhhhh!!! Nooo! My brain hurts, Mr. Gumby!... inches like 3"3/16
While I'm comfortable using fractions because it's what I grew up with, once I learned about the decimal system it became my preferred unit of measure, so can understand why metric would be preferred over fractions.
Unfortunately though, many of us have Imperial units so mentally ingrained in us that while converting to decimals is no problem, converting them to metric with what amounts to odd fractions/decimals is tough, so can sympathize with those raised on metrics trying to convert to fractions.
GM
GM
Yeah, strait Banana's, standardised Carrots, Potato's, Tomato's, Onions, Lamb and Pork chops.
297mm x 210mm sheet of paper = A4.......... come get me Euro cops.
Makes you wonder how retailers get away with selling me a 38inch lcd tv?
Tis a good job the Euro nannies dont visit my shaping bay, custom surfboards are discussed in Imperial, laid out in Metric and once shaped, the dimensions are written on the shape before glassing in Imperial. One shaper started to write the dimensions in metric and his sales fell - surfers didn't know what size boards they were buying!
On Topic:
I've been playing with Horn Response for a while - maybe 18 months or so and still cant make head nor tail of it
OK, here are the horn cell dimensions of the 1005 as best I could measure.
Going from the mouth back to the throat at 20mm intervals. It was not easy to be exact, as the walls are coated in a rough aquaplas, with bumps and dimples.
You'll see 3 columns, the right most is the measured outside minus 3mm. That's about the difference I measured at the mouth between inside and outside. With aquaplas and lip, it could be 3-5mm difference inside to outside. Take it with grain of salt.
350mm is where the horn goes into the flange, I could not measure beyond that.
If you can get Hornresp going, you might be able to find the actual profile numbers that match this curve. Have fun!
Unfortunately though, many of us have Imperial units so mentally ingrained in us.....
GM
I know my height in feet & inches. It just doesn't sound the same in cm. On the other hand Mrs JRKO like to measure her weight in Kg's as she's no idea what it means 😀
Another one who doesn't get HR!! Maybe its one of those jokes where those in on it know it doesn't work but recommend it for a laugh?
Come on fellows, all you need to know to convert back and forth from inches to mm is the number 25.4 the conversion factor. As far as measuring an old Altec multi-cell to get the dimensions is a fools folly. I bet no two Altec multi-cells measure exactly the same, they were hand made. All you need are a few numbers to figure this all out. The initial cross sectional area at the start of the horn and the mouth size that you want for cutoff. As far as the length goes that is a little more complicated as you can for-shorten or extend the length without affecting the cutoff frequency in a significant way. First of all design the horn lens for a multi-cell as a single horn lens. After you have that basic sizing calculated just divide the total surface area at any distance along the axis by the number of cells you require. The basic equation that you need to know is
So=Si*e^mx Learn this simple algebraic equation and you are on your way to being a horn designer. It would be easier to help here if I knew all the hidden keys for mathematics. The basic numbers are as simple as taking the number of the speed of sound in air at standard conditions which is 13,548 inches. Take that value and divide by the frequency that you want for cutoff and divide by that value. Then divide by 4 as that is 1/4 wavelength the magic number for a useful cutoff frequency. This can also be used as the length of the horn lens at 1/4 wavelength the common method of design here.
I forgot who asked the question what I would make a horn lens out of. My original design work with horn lenses was to develop a mathematically correct shape that could be inexpensively produced and that material was polyurethane foam materials. I hold a now very old and open source patent for that design. I actually had the first patented design using foamed plastics to produced any horn shape. I could have made more money suing others for that reason than making lenses themselves but never did that. As far as making a paper horn lens I don't see why not if that is what you really want to do. I would probably just cut out the shapes from mat board and glue the sections together with Cyanoacrylate adhesive. Then you could easily wrap that with fiberglass material or just coat the paper with epoxy resins. After that you can fill the open space between sections with some filler material.
Call me a fool, then. (See my post above). FWIW, the cells on mine all measure pretty much the same, within a mm - considering the coating. I guess the metal parts were cut from a template.As far as measuring an old Altec multi-cell to get the dimensions is a fools folly.
As to how critical it all is, I would guess it's not too.
I'm not all that familiar with all of HR's options, especially with all its more recent upgrades, but the basics are simple enough once you know its 'ground rules' listed in the HELP doc.
To generate a single segment horn profile, all you need do is follow the HELP's instructions for Horn Parameters S1, S2, L12, T. All the other field’s values are irrelevant!
Click Calculate.
F12 displays Fc.
AT displays the throat’s half angle in degrees if you want to know how it lines up with a driver’s exit angle.
Cir displays the percentage of mouth area to a full size horn based on the local boundary loading specified in the Ang field.
Click Window/Schematic Diagram in the taskbar.
Click File/Export/horn data in the taskbar to pop up the Export Horn Data window. Scroll down to this section of HELP if you have any problem figuring it out.
Once any changes are done [if any], clicking OK pops up a window to save it as a txt or csv file [you choose], which can then be opened in an appropriate program to view all the horn’s dimensions at whatever expansion distance specified and/or generate a drawing to print out templates.
HTH,
GM
Click Calculate.
F12 displays Fc.
HTH,
GM
I see that I have an old version and so what you say above just isn't working at all for me.
Will try a newer version
So=Si*e^mx - Learn this simple algebraic equation and you are on your way to being a horn designer
But I'm no further along until I know what the designations So, Si,e & mx relate to. I'm guessing sos & wavelength/freq. are in there somewhere😕
Do I enter 0.0 for the other cells?
GM
Thanks GM. Is the txt file the list of distance, radius, area etc I've seen on the exponential calc? What are the 'appropriate programs' to send the info too?
I'm going to use the measurements Pano kindly provided to build a proof of concept cell or two. By the time I've narrowed down the particulars of build method I hope to look at replicating using HR for exact plots.
- And Now For Something REALLY BIG
