temporarily remove the reg and use the -24Vdc direct to the fan.
Don't get the zero volts mixed up (that part of the sch is upside down compared to conventional).
That should work.
That should work.
That should work.
Thanks Andrew! it works...
Wiljj78
B500 based on schematics of H900, but in AB class.
Power supply +/-90Vmax.
A and B.
The points A, B; for serving
what is its use
Hi guys!
I was doing this layout and I'm not sure if I got it correctly I spend maybe more than 5 hours or more, please is some one can see any error please let me know I have also the Sprint Layout format so you can use it too, I will share this for you guys. my brain is like this![]()
vargasmongo3435
Hello Juan,
Please note there is open track on 4148, see attached pic.
A and B.
what is its use
Hi Sergiods,
Read post #1301.
Hi good morning, how's it go this morning? With me it can go well, if I short out my amplifier and get it work like I wanted to be. I attach some pictures to show you how it looks. If you can see the left side of the 2sc5200, they not warming up like the right side of the 2sa1943 transistors. When I power it up with dc +55v -55v the right side of the 2sa1943 transistor the first transistor from your left side getting very hot and burn out. I build it exactly from the schematic like it is. But but still getting the same problem with it.
https://fbcdn-sphotos-h-a.akamaihd...._=1350600003_c475955c69fd930f8339a0a4f65208a3
pls give PDF file this PCD
I offer an apology for my mistake. This is the picture where you see the flaw and the transistor burns
thanks mile ,
I've already have two schematic for 2ohm loads. which one is the best ?
B500 with triple darlington or B500TEF ? do you have another schematic for TEF ?
because i think B500TEF schematic isn't correct. for example it seems to operate with lower rail voltages. (15A fuse - BD681 ,etc)
Hi mile ,
Can you help me for 2Ohm version ?
IRSound
B100 & B500 TEF
Thanks APEX, this is my second B100, and Driver B500 TEF the first time I've made, I want to use the 8 pairs toshiba, how many volts do I need for the maximum and minimum Ampere Transformer? how many watts I get to 8 pairs of Toshiba?
Sound is get very clear and very nice, power is one of my favorites.
greetings. Damanhuri
Hi Damanhuri,
If the orange,orange,orange,silver (dark brown body) a resistor or small inductor,
on bottom left of blue pcb,
It looks like little chokes I have.
For 8 pairs use 1200VA transformer 2X80vac maximum.
Thanks Sir APEX
B500 with to3 output transistors,pcb done by member d.veljkovic:
Nice and usefull,
😀 hey bro! you are using my woofer drawing hell yeah! by the way nice thinking of having TO-3 transistores.
vargasmongo3435
yes-the pcb has been modified from someones sprint-file and it is probably 99% yours. we haven´t noted whose it was,we liked it and copied,i hope that you are not angry about that...
yours b500 based on this pcb is working?
angry me ? I'm happy come on guys! lol no I haven't try yet but soon, I made the layout a couple of months ago here is: do not mind about the woofer is sharing art. 😀
Juan
Juan
Juan
all right than 🙂 we are walking on the same side of DIY!
- 500W PA amplifier with Limiter
