got 2 for my Dual Mono Buffalo II 😀
Got a ship notice, two on the way for my dual mono. Plug and play!😀
AVCC module is listed along with the Tridents in that section.
Waiting on mine, anybody get one in yet? Impressions?
I popped one in over the weekend. It has made the biggest difference in my BII since synchronous clocking it. Less clunky/mechanical, at $40, it is a no brainer IMO.
Nice 🙂 I have ordered for 2 dacs.
Glad...
We agree on this upgrade 🙂. I put the new AVCC in my DAC at the end of last week and the improvement was far from subtle...
When I get my nCore set up going again I will be interested to see if this new AVCC helps solve the RF pick up problem I was getting from my USB inteface I2S wiring. My Pass amp does not exhibit the problem...
Drool...... tic toc
is this the same AVCC that comes with the current Buffalo 3 kits?
Yes.
Ha!
I think we agree on more than what might be readily apparent- this hobby is fraught with trade offs and assumptions.
I have ordered the new version as well. But what to do with the perfectly working "old" one?
I would like to use it in the OPUS DAC, thus needing to change one leg to 5V. Doable?
Hi Russ/Brian,
How to adjust the output: (eg 5V for OPUS)
AVCC 2.1 !!!!!
Mine actually was un impressive for a few minutes, took some time to settle. Very nice now though.
No - unfortunately changing the output to 5V is not really practical with the old version on which you would have to change the opamp and a few resistors - but even then it probably would not work well because it was not designed for that.
If your keen to try it I can give you some guidance privately. It would be no small undertaking. 🙂
On the new version you could probably do it just by changing 3 resistors. I could calculate those for you if you know what your input voltage range will be.
Cheers!
Russ
Hi Brian/Russ
my new AVCC Arrived in this morning’s post.
WOW that was quick.
I’ll post some thoughts once I have her plugged in and warmed up.
WOW that was quick.
Hi Brian/Russ
WOW that was quick.
Grab a drink, and get ready for a treat!
I’ve had BuffaloIII with new AVCC playing for several hours now and agree with previous posts.
The lift in clarity and detail retrieval is far from subtle and the overall improvement it made to the sound was obvious.🙂
Not that the original was any slouch but the new AVCC is just better.
It’s sounding really, really good. 😎
The best $40 I’ve spent in quite some time and as 4est put it ‘’a real no brainer’’.
Thanks Russ/Brian
Thanks Russ/Brian
- More Vendors...
- Twisted Pear
- AVCC 2.1 - module update
