JLH Headphone Amp
Hi blackdod,
thank you for pictures, I don't believe uploaded schematic applies to your version of the board. If you are worried about those lifted tracks check for continuity with DMM to be sure , however I don't expect problems there. Cleaning the flux from the board with some alcohol wouldn't hurt either. If you feel confident and you are good at desoldering change input ceramic cap to 1uF film type, not sure if WIMA would fit here because lack of space, if not try Panasonic ECQ-V series. If all goes well replace two Zener diodes on the board each with 4x1N4148 connected in series, observe the polarity it is opposite to the zeners.
Marko
Thanks Marko
I followed all scheme and is not compatible with my amp on some points. 😡
I'll think I do. I did not want to spend much time on this amp because it is a "smaller" project and I have other amps outstanding. 😕
Thanks for your patience 🙁
Hello blackdod
The biggest difference between your green PCb and my blue PCB, is that my heath sink is at least twice the size of yours.
But if you mail me your postal adress, then I will send you a blue PCB at no cost.
:worried: Thanks Max but I can´t accept that. Let me pay you the plate and sending.
I will change the input ceramic capacitors and some bridges because are rusty only by test.
If output coupling caps are added to protect the headphones from the output dc offset, is there any reason to aim for 0V dc offset upstream of the cap?
I have a pair of ASC GLY513 600uf fim caps that I'm mounting in a separate enclosure with 6.35mm stereo in and out to allow me to use these caps with any headphone amp I'm using. With these film caps it won't damage anything if the offset is positive or negative, but I wondered if setting the offset to +1vdc (making the signal vary from 0-2vdc in normal use) would be best.
In the meantime I have a pair of black gate 1000uf 16v standard polar caps at the output, so setting the offset to +1vdc keeps the polarity of the signal correct for the polar cap.
Any thoughts?
If you use a capacitor at the output , it might be better to use a single supply circuit. That would bias the output cap at 1/2 Vcc. Electrolytics with no dc voltage across them aren't really operating in a comfort zone. Even a non polar electrolytic might not be the best solution here.
Like oz7aff said. Try out the way you want to do it and see how it sounds. It finally depends on if the sound is acceptable to you.
Have fun !😉
Well actually, you only want as much DC across a 'lytic as is necessary to keep it in good working order. At higher voltages, distortion actually increases, as Cyril Bateman found. Introducing some DC offset should be easy in the JLH, as it requires some offset trimming anyway.
Basically the largest disadvantage of using coupling caps is their size. Ideally you're looking at something like 1000µF per channel.
Blue PCB:
On a hour, the offset is constant, around 15 mVolt more less. The sound is good. I think that the board desing (the path of the track and its travel is totally different) and the quality component is the differece.
I think that the green board "JHL" it´s a c***p...😡
