Triple driver - sealed. Pros/cons, and is it too much for a newbie
Minor point:
Subs radiate omnidirectionally.
This does not mean that their source can not be determined by a listener. This is something that seems to have gotten confused by an awful lot of people.
_-_-bear
Bear,
Minor point additions to your minor point addition:
Subs radiate omnidirectionally only at very low frequencies, and progressively become more directional at higher frequencies.
The larger the piston diameter, or distance between radiating surfaces, the more directional the sub will be to a lower frequency.
Horn loaded subs are in general more directional than front loaded subs.
The more shallow the crossover slope, the more obvious the directional control the sub has. The "sub" output on many home theater units may have output extending past 500 Hz, octaves above the point where subs are "omnidirectional".
Art
get an analog meter if possible... and actually skip the SPL meter, go directly to freeware FFT software and a cheap measurement mic, DIY per Linkwitz being the starting point. At LF the soundcard in any computer is more than good enough.
regarding the TH (tapped horn) response posted, the lower range looks too flat to be believed, but the upper peaks will require a really sharp filter to get rid of, since they are very sharp and rise >24dB.
A "standard" 4th order won't do it.
A "standard" 8th order will have to come in lower in frequency than desired in order to pull that down enough, which *if* that works in the system might be acceptable.
You'd need some DSP or some trickier filters to tame those peaks, imo.
_-_-bear
Bear,
Art
If we are going to be specific, then almost all sound radiates omni-directionally, certainly low/mid frequency sound does. When we speak of a sub being omni directional then we are talking about an inability to locate the source of bass. Our ears can locate the source of sounds down to roughly 100hz, below which they no longer can. I dont agree piston diameter has anything to do with subwoofer directionality. A sub becomes locatable by ear when it produces frequencies high enough to enter the range in which our ears can locate the source of the sound. Typically, this is down to distortion/harmonics etc, but can also be due to very high crossovers. If your going to crossover above 120hz, then its advisable you only do so if you run dual subs that are located very close to your front left and right speakers, as that helps maintain the illusion of being unable to locate the source of bass. Ive used 18 inch subs and had no problems with achieving the invisible sub bass effect.
Thanks so much guys for all the input.
SNIP....
Regarding one time project or not... Safe to say, I am being sucked to the dark side of DIY. I have always enjoyed screwing around with stuff, and have always had a passion for music. So I am probably in for the long haul. Feel sorry for you guys - you may be stuck with me for ever "evil laugh". In that same vein, is there some "basic DIY survival kit" that I should be looking at acquiring. That would be an awesome other post - or publication, recommendations for equipment for newbies.
SNIP....
Yes,
A second job
Welcome to the dark side.
Dave
Doh.. Had to buy a laptop for my RTA software
Hi bear,
According to the people who have build the double fold version of the TH the peaks are nowhere near as pronounced as they are in Hornresp. Basically, a 4th order @ 80Hz would do it. If you read through that thread, you'll see, that part of the "smooth" response in the passband is the result of a series 5mH inductor.
If we are going to be specific, then almost all sound radiates omni-directionally, certainly low/mid frequency sound does. When we speak of a sub being omni directional then we are talking about an inability to locate the source of bass. Our ears can locate the source of sounds down to roughly 100hz, below which they no longer can. <snip>
I can't fully agree with this.
all sound does not radiate omni-directionally, it is true that as frequencies descend then the radiation becomes more and more omni-directional.
But if one takes the case of a basic dipole woofer, then it's not omni-directional at all... 😀 (for example)
and if you move the subs a certain number of ms of delay away from your main speakers you will certainly hear that as an audible discontinuity... similarly, set your sub or subs off to your left and right, have the delay time between them and the main speakers identical to your ears, I expect you will be able to easily detect the positions of the subs...
in my experience, if your system is such that there is continuity in terms of how an impulse is reproduced (things come out in phase and add properly) small differences in delay or position of the subs effects the way that individual instruments are heard - especially things that have LF components. When I say "way" I mean the sonic character and importantly the way that the spatial aspect works and how the sound stage resolves...
the gross frequency response likely varies not enough to register as being significant.
_-_-bear
1. Regarding the TH. The graph seems to taper off pretty rapidly below 25 hz, with about 5dB down at 20 Hz. Is this something that a little DSP (or possible in-room acoustics) should take care of - eg. with the inuke 6000DSP to make fairly linear down to about 18 Hz or will that be difficult, and likely too demanding power from the amp
2. Given the peaks etc as you go higher, will crossing over at around 60-70 Hz take care of that?
3. What exactly are the guys on the TH post referring to with inductors and their role in THs.
4. Does the TH design in question need lining in the cabinet? My initial impression is that the design depends on reflection of the sound through the horn, and absorbent lining may defeat the purpose.
5. If I want a fairly linear output to about 18-20 Hz, is this a good first step for me? When I say fairly linear, I mean it doesn't have to be perfect on a graph, as long as it is linear to most the ears.
As posted earlier by tvrgeek, there is no magic recipe for the perfect sub, waiting to be just shared, and built/sold by everyone, but... as someone who values all your opinions, and if you guys convince me to spend up to $1000 or so, I would like to hear your opinions, dollar for dollar, what design should buy me the most linear sub down to about 18 Hz. I realize this is opening can of worms, but keep in mind the suggestions are for someone who has never built a speaker before, and I really would want to hear varying opinions - comparisons.
I get the sense that the sealed sub is not very popular here. Is it because it take too much power to keep it linear as you go lower, and or that it is far more demanding to eq requiring more DSP/processing etc., or both?
Is it much to harder design and construct a ported sub tuned down to about 18-20 Hz (up to about 60-80 Hz), and am I looking at a much larger sub then a comparative sealed unit?
Size is an issue for me. I can stick a vertical TH in the corner, but a box, would have to fit under my main bookshelves without looking to massive - and that is where the ported designs scare me a little.
Funny, I started this post, with an assumption that sealed subs are more linear and musical but now I am entertaining all these other interesting designs. My biggest impression came from a direct comparison of the sealed and ported HSU research subs - I heard the sealed 15" and the VTF 15", and although the HSU VTF ported sub, was notably louder, it couldn't hold a candle to the sealed 15" HSU in terms of musicality and to my ears, linearity. The sealed just went lower, and was far better with transients, without over hang or any appreciable bloat. The ported VTF was no doubt louder at certain freq, but it seemed almost unnatural the way it suddenly dropped off. Almost like something was missing, even though it gets a good 20 Hz output. I am not a speaker designer and can't explain it, as the sub goes plenty low (lower than my current sub which only goes to about 30Hz), but something about the gradual taper vs the steep taper gives the ears the illusion of a more natural and musical presentation. Can't explain it any other way other than an illusion - perhaps some one on this forum can explain it more technically. Or perhaps it was the quickness of the subs that gave that illusion not the gradual taper, and the sealed was more immediate and in control? Dunno, any thoughts?
Now that I have mentioned the HSU subs, how would some of these proposed designs compare to those. My personal impression is that they ran out of steam a little early, as they are a tad underpowered esp when comparing to SVS and other mail order subs, but they were nonetheless a pleasurable listening experience.
Regarding amps - any other suggestions to consider other than the behringer inuke? Or is that sort of the go to amp here. the 6000 DSP can be had for about US$450 on amazon, plus taxes. Good buy? That would leave me about 400-500 for a quality driver (or two) and cabinetry - but I'm guessing it would sound better than any $1000-1500 sub I can buy!
My two bits about omni direction...
I always got the impression that subs were difficult to localize due to humans inability to localize sounds below a certain frequency (120Hz). But any harmonics/distortion may make this vary a good bit as that is beyond the control of a crossover or DSP or whatever, as it is produced mechanically by the driver/surround/cabinet etc. Thinking back to high school physics, lower frequency waves have a higher propensity to diffraction, and therefore reflect of nearby surfaces etc. as compared to waves that just push straight forward.
So wasn't sure if the argument is about perception, or true direction of the waves, but they are both sort of correct. Ears have harder time perceiving direction, and, lower frequency waves diffract like a SOB, and are harder to maintain direction.
2cents from the newbie. Feel free to rip up my warped theories!
Question about Behringer amps.
On a quick comparison of the spec sheets of inuke and the europower, it seems that the europower might be the better amp - at least on paper. The freq response is better (-0.1db at 20 Hz vs 2db), and the power consumption ratings seem to be more realistic (couple of kW vs 600W).
Does anyone have any experience with those amps?
The power consumption may be misrepresented in the inuke sheet as some of the models were listed at 1/8 power, and I don't know if that was an omission, and the 600W consumption is at 1/8 power.
_-_-bear
Not all sound, but almost all sound does. All you need to do is stand behind a speaker and note you can still hear it, to kinda prove the point. Inability to locate the source of a sound is a function of the ear, rather than the speaker. Of course, the speaker must only produce frequencies that cannot be located by the ear. Audible discontinuity upon changing a subs distance is because of a phase shift, and the resulting degraded impulse response.
MedPad, the advantages of a sealed system are:
Smaller
Better system integration due to phase (see linkwitz and reilly)
Better control over the overall sound (system Q)
Typically better impulse response (better system damping)
Deeper
Disadvantages can include:
More expensive for any given performance level (spl vs freq)
Need more power.
Low end performance is dependant on proper eq
Less output vs other designs (less efficient)
For me, the sealed system is best no question, but that is based on the caveat you need to spend more money and have enough power and enough drivers to meet your performance criteria. High performance sealed subs are always going to cost you more, but its a price I feel is worth paying. If you going to run a single sealed 15, then you need to be aware of the limitations of such a system in terms of raw output, because its just not going to match non sealed designs. I think you need to focus on whats most important to you first, then choose your subwoofer design based on that.
Not all sound, but almost all sound does. All you need to do is stand behind a speaker and note you can still hear it, to kinda prove the point. ...
There are always reflections and that's why you here the speaker from everywhere.
If you could suspend the source of the sound in mid air, a kilometer from everything, you still would here it because it reflect off its own enclosure (dispersion)
Don't rule out the time delay between the left and right ear, very sensitive localization!
A good example of such a source is a jet passing high above. The sound still radiates omni directionally, like the ripples in a pond when you throw in a pebble, only in 3 dimensions rather than just 2. Its often difficult though to localise the direction the jet is, because at a long distance its mostly the low frequencies that reach you, and your ears arent sensitive to directionality at low frequencies. If you have two subs, at different distances, and this isnt accounted for, all you get is an effective blurring of the bass, but it doesnt make either subs location noticeable if they are both only producing low frequency material, you simply get poorer quality bass, which also affects the rest of the system.
Thanks moonfly.
That is sort of what I was thinking. Based on what I have heard, sealed is better to my ears. (I havent heard THs). Question is, at what cost. Am I delusional in thinking I can make a sealed sub for under one grand which will get me usable 18-20 Hz output in my room. I am not sure in spl terms, but would hazard a guess and set about 115-120 db as my goal - after eq.
If it isn't possible, then I would go for a ported or TH design, as they do offer more bang for the buck. And the drawings for the single fold TH seem very doable. Thank you Oliver. I am a bit apprehensive about timing etc with a TH, and don't know how much of an issue that is.
If a sealed could meet my goals under my budget, then recommendations for components would be appreciated. I'm still quite confused about the various drivers, amps, and how to eq.
BTW, in looking at drivers I couldn't help noticing how sensitivity goes own as drivers LF range begins to extend beyond (lower than) 35hz. From above 90 to the mid 80s. Likely from increased reinforcement of the cone. How relevant is that? It seemed fairly significant.
I am curious to experiment more once I have my setup up and running with the basic setup first.
Again, thank you all for your time and advice.
If your considering going sealed then you also need to consider how physics will play it part. Making sound is about making a pressure wave in the air. To go louder you need to move more air, to go lower you also need to move more air. At about 25hz, your ears also have a natural roll off to low frequencies, so you need further increases if you want below 20/25hz stuff audible. To move more air, you need more driver area and excursion, especially so in sealed systems as the front of the driver is entirely responsible for moving this air.
Its easy to see how in a sealed system, larger drivers with higher excursion will deliver more. Any performance level is achievable, you just need adequate ability from the system. This generally means using larger drivers, or more drivers (or a combination of the two), and adding more power, until you achieve your goal. Larger drivers pretty much always need larger cabs, so thats something to consider. As a point of reference, a pair of Fi Q18's, each in a cab size of (150)-250 litres, each with about 1500 watts, will give you about (105db) 110db @10hz or 115 ish at 20hz. This assumes your goal is a flat response to those target frequencies.
A quick note on the NU6000DSP, which I own. Each channel consists of a bridged amp module, thus the unit CANNOT BE BRIDGED, not can it safely handle a 2 ohm load on a single channel. It's basicly two bridged NU3000's on one chassis.
It makes the rated RMS power one channel driven, ~2200w. See this this review for bench testing:
Behringer inuke NU6000 vs KAM KXD7200 bench tested - Speakerplans.com Forums - Page 1
As far as I know, it's the most powerful amp ever produced under $500.....?
<snip>
Try this outside with high freqs and call me back... you hear a speaker behind it because of reflections in the room, for the most part. Yes, the bass likely does radiate to the rear somewhat, but again outside you'd be surprised at what does not get there at all...
also you won't realize how beamy most speakers are until you listen outside (or in an anechoic chamber), because inside the "space" gets "filled up" by reflections galore.
_-_-bear
_-_-bear
The jet is a poor example.
First off most of the sound a jet makes is due to supersonic production of sound (inside the jet engine), secondly, the jet sounds noticeably different depending on your position relative to it's position WRT coming or going. Thirdly, due to its distance it is effectively a point source.
And the reason that a jet at a long distance, but over the horizon is difficult at times to localize is due to reflections of the audible sound, causing the ear to determine that the jet is where the source of the reflection is not where it actually is.
_-_-bear
