All Diyaudio Threads about not available Optical Pickup's from Sony's KSS-Series
There are only compatybility in optical system and electrically.
Mecanically samsung sohot4 has totally different dimentions.
There are handy work for sometime
Naturally there are multiplicity of problems
Cutting works of sohot4 lasts endlessly
Optical centre is crucial
Adopt sohot4 to kss151a frame is all pain
... from all laser units that I know, Sony's laser heads above KSS-120 by far the worst of all (life time, reliability), even the models for the ESPRIT series like KSS-272A. Two main reasons are therefore responsible:
1) the suspension of the collimator lens (plastic leaf spring instead spring wire)
2) the diode itself...
Timely, thanks, as I begin to grapple with a CDP101 whilst waiting anxiously for the arrival of a CDP102, and hoping to swap the both of them for a 337ESD. If the lasers don't work I'll be stuck with a heap of heavy metal.
So far, I've been very pleased with the reliability of CDM2 and early CDM4 mechs, and the plastic Philips cases they commonly live in even have a moulded dock that fits the nose of the loader so you can up-end it in situ and run it vertically for servicing. And I love the equally well-engineered Toshiba plastic and steel machines that jiggle and fuss but get the job done come hell or high water, thanks in part to their plastic springs.
I was looking forward to these Sonys with trepidation because of all the heavy metal, and consequent inertia in mostly the wrong places. Not nearly enough plastic.
So what's wrong with Sony springs? How many Sony machines have been dumped for want of a spring? Sony will almost certainly have bought far more springs than they needed, so I wonder where's the remainder. Where are the moulds?
Philips plastic-and-steel CDM2 and CDM4 seem to last well, and could last longer were it not for the abuse they receive, not only from ignorant meddlers but also from the ill-considered unregulated voltages they are often supplied with.
Possibly the same is true of the commodity-grade KSS150A. It has a laser that seems to last as well as most, and when it eventually inevitably fails, a replacement can be found quickly and easily in a skip or rubbish heap, or on ebay for next to nothing.
Heavy metal is a fetish. Learn to love plastic.
Ian
KSS190A bar t'at. Sorry Osvaldo :mischiev:
Investigating a loudening rotation-speed ticking, now focusing on the, er, fucusing. Sadly suspecting a weakening laser 🙁 Eye pattern manages just 0.8-1.0V
I notice that the radial motor sensing coil is 6k when it should be 2k according to the manual. I can't see how a single coil can go wrong, so I assume the manual is mistaken, again.
Anyone managed to replace a laser/monitor diode in one of these yet?
I've just noticed on the second photo that the rim of the lens holder appears scuffed. No sign on the CD, but perhaps it's moving too close?
That lump of plastic isn't nearly as good as the spring on the Tosh in my avatar.
That clump of threads is a tangled web.
It's not clear what is compatible with what. Does the 337ESD with kss190a contain the SLD-104U or AU, or what?
I'm not really equipped for working with the kind of precision necessary to align a laser head unless components are positively located and are of same dimensions as original.
I don't want to touch the laser until I know it's nearly dead. Some new caps around the servos have allowed me to adjust focus gain and bias to reduce the ticking sound to a low level and increase the rf voltage to 1.1V so it may limp along for a while.
There are "C04 6FR" diodes on ebay, sold for kss151a, but I don't know if they are suitable.
Have anyone managed to fit one successfully? If I felt I had a reasonable chance of success, I'd be happy to do it and document the process.
check out various SONY service manuals from those models, where is in use both KSS151 and KSS190.
I have Sony CDP-501es and I belive it needs laser replacement. Disc spins for few seconds, then stops and tray comes out. The laser assembly is KSS-100a.
1. What is the way (procedure) to establish that laser is at fault?
2. This laser assembly is impossible to get; can another laser diode be substituted, and which one?
3. Is laser light of that particular one visible light or infra-red?
Thanks a lot...
...also, after reading "Laserology" I can add the following:
- if assembly moved to the middle of tracks, it will come back to the most inner position.
- I was not able to notice laser moving up or down in attempt to adjust focus...
Thanks a lot...
Check RF level while disc spinning. If the level is less than 60-70 % of those level from the service manual, laser diode must replace (never done until know by KSS-100A).
At best you order a second CDP-501es device in working condition and now you can compare various parts for checking. Other way for troubleshooting are very complicated and it is very difficult to get clear statements.
http://www.made-in-china.com/showro...HVp/China-Laser-Pickup-KSS-123A-KSS-100A-.htm
Sony deploy any number of fail-safe mechanisms to avoid setting fire to countries with tight regulations. Check that the laser and focus servos have the correct voltage on their supply pins.
If you have a manual, you should find a procedure for checking the laser/pd unit there. You may need to defeat the eject response by connecting a pin to ground or some voltage...the manual will show which.
Sony boards are usually very informative.
According to Sony notes on laser diode emission check, I did following:
1. Ground servo amp board TP12 (IC102, pin 30 (LD ON)).
2. Observe the objective lens and confirm laser diode is emitting light.
No light was observed..
Focus search operation check:
1. Block the disc detection photo transistor.
2. Press PLAY button.
3. Observe for objective lens movement up and down 3 times.
No movement was detected.
RF Offset Adjustment (BTW, what is RF, sorry...)
1. Turn power ON.
2. Connect oscilloscope or VTM to audio board TP3 and TP4(ground).
3. Adjust RV7 so that oscilloscope or VOM reading is -0.4, +- 0.1V.
I did not do any adjustment, but I measured -0.338V.
Does all this mean faulty laser diode, or I can stil hope that there is fault somewhere in circuitry?
To PlasticIsGood, that link to Chinese site for KSS-100A did not work...
After a little bit more investigation, I found that there are three wires going from APC board (don't know what APC mean) into Laser head. One read 1.7V, next 0V and third -4.5V. As CD lasers are usually powered from 1.7 - 2.5V, that would mean infra-red laser, as they have negative voltage for common. So, seams all voltages are present, what leaves me with dead Laser diode...cool!
I guess I am now going to open had assembly and see if Laser can be replaced; any suggestion - where could I find, buy, these diodes, what type... Thanks.
Automatic Power Control?
Is there still a possibility that the LD has become disconnected from the voltage you have measured?
Sorry about the link. If you google kss100a you will find the page, complete with picture of the mech. It may no longer be current, because if I search the same site it comes up with nothing. Strange.
As for the laser, I'm hoping someone else takes the plunge before I'm forced to. Even though the head on my kss190a is huge, disassembly still looks like an irreversible process. If you can find any reports of success with LD transplants, I would be glad to see them. There are several types of diode on sale, and it seems people buy them. The chance of successfully aligning it with the PD array seems very small to me, unless it's positively located and a replacement is exactly the same shape.
With a more normal-sized head, I'd be looking to graft a complete assembly to the existing sled. Then all I'd need to do is ensure the lens is precisely located, with a rigid jig made before disassembly, that positively locates on the sled, and has a pointer touching the centre of the lens. I'd hope that the control system would cope with a different coil/mass/spring combination, but I think many Sonys share the same control circuit.
Actually, it looks very similar to KSS-122/123A, just they have black plastic cover over the actual metal laser head. Can someone confirm that it is actually the same round head as KSS-100A? Send me a close-up pictures if possible?
Some POSITIVE results; I disassembled head assembly, was able to see photo diode array, but didn't take laser diode out. Coils look fine, no trace of burning. Put everything back together, guess what - it WORKS!! Not the hole CD player yet, but lens is moving in and out, and laser diode lit up for a second and then slowly decays. CD disc was before spinning like crazy for 2-3 seconds, now it does not spin at all, just tray comes out as disc was not detected. Now I have motivation to keep trying... Perhaps I should re-install STK9622, focus may be working but tracking drive may be faulty...
From TVK not too long ago . . . worth a read . . .
Here's the quote:
"The Vintage Knob‬
Sony CDP-X779/707ES & other models using the same transport‬
‪ ‬by ‪ilimzn‬ » Mon May 16, 2011 12:01 am
Also titled: are you sure it's the laser going bad?
Users of these fine machines and also related models using the same mechanism based on the KSS272A laser block, that have problems with their machines readong some discs, may find this of use:
Two problems that often crop up that look like the laser may be going bad, but are NOT laser related at all, so be sure to check:
1) One or more of the following happens:
- Inability to read the TOC, after which the CDP stops with '0' on the track count display and with the track display off. In these cases the CD may not respond to the keyboard any more until it's switched off and back on again. Sometimes the error goes away after the CDP sits switched off for a while.
- Sudden failure to red the disc (often with some prior skipping), if eject is pressed immediately, the disc will still be spinning and ends up 'grinding' on the tray.
- CDP starts skipping periodically but not at the same rate as the spinning of the disc. Ejecting may also produce the 'disc grinds in drawer' effect.
The cause of this problem are cold solder joints on the mechanism controller, the two-sided board fitted to the actual bottom of the mechanism. In particular, in most cases it's an intermittent contact in the small 2-pin connector, closest to the front panel. This carries the supply voltage for the BSL spindle motor driver chip. The actual symptom has to do with this chip losing one or both supplies resulting in uncontrolled spinning or failure to spin. It is not easy to spot until it really becomes bad because the servo system can correct this. At some point, it cannot any more and the motor either 'runs away' spinning like crazy - this is the 'CD spins in drawer' case - or stops completely - this is the 0 track, no track display case. The motor is so silent even if it spins like mad that it's very hard to hear, unless the case is open and you can see it happen. In some cases it can even start spinning on it's own just sitting there without a disc, or with a disc but in a stopped condition.
The reason it happens is that the driver chip heats the PCB which results in cold solder joints on the connector nearby (even more susceptible because of the cble flexing when the disc is loaded or unloaded) and the chip itself. In these cases it is advisable to carefully re-solder the whole board and then wash it in isopropanol or PCB cleaning spray (resoldering requires putting liquid flux on the pins of the chips etc. and leaves a residue after it is done). Remember to check and resolder both sides of the board! This is a precision double-sided affair so be sure you know what you are doing. The laser head flat cable needs to be removed, careful, this is static sensitive!!!!!
The above problem pertains to all CDPs with the same mechanism, that would be CDP-X303, 339, 505, 559, 707, 779 and corresponding Japanese model designators.
The following problem is speciffic to the CDP-C779/707 (and Japanese market equivalents):
2) Nasty skipping on damaged discs that should normally be readable at most with sound degradation or muting, and are on other machines. In advanced cases it may skip backeards and just keep repeating the same part of the track ad infinitum.
The way to check for hard errors and susceptibility to them is to load the suspect disc and try to go fast-forward through it. In this case the servo system is more susceptible to losing the track, which can be seen in the time display - time is lost and more often, skips backwards a few times when a hard error is encountered, after a few times it can then skip forward by several or more seconds - this is common to most implementations using the CXD2500 decoder chip and Sony CPU to control it, the CPU detects repeated problems and tries to skip 'over' the problem area. Repeated skipping backwards only to repeat it again is a sign you have this problem - in fact, it is highly probably all X779/707 have it, but doe to tolerances, it may be more or less visible.
The actual problem has to do with what must be a manufacturing flaw. In particular a resistor with a wrong value has been used on the digital PSU board. The reason the problem happens is instability of the Vee negative supply (incorrectly labeled as 1.7V in the service manual, corrected in a supplement, should be 3.7V) under load. It is easy to check for this problem by using a voltmeter between the chasis and the copper heatsink on the digital PSU board edge closer to the front panel, righ next to the filter cap. If you see 3.1-3.5V, your CDP has this problem. It is present in the 4 I have here, and because the wrong value of the resistor is clearly documented in the service manual, it is likely they all have it.
The Vee negative supply is generated by a simple linear regulator, 2 transistors and a zener diode for reference. The clue is that the zener diode D959 is rated at 4.3V but the voltage on it is usually below 4V. This is so because the resistor R961 feeding it is way too large at 4.7k - the current through the zener diode is far too low to establish proper zener diode operation. The result is that D959 operates at a working point where it's internal impedance is very high and unstable, making Vee very variable under load.
When the CDP encounters an error, it needs a much larger current to control the laser head, and demanding it from Vee results in collapse of the Vee. Because there are a number of circuits using Vee (including the spindle motor mentioned in the problem above!), a large amount of the drive electronics starts operating improperly at that moment, the servo circuits lose control of the head and reset, which incidentally makes the head skip uncontrolably backwards a bit, resulting in the nasty skipping.
The solution is simple: change R961 from 4.7k to 820 ohms.
There are a few optional steps that can be taken to further improve things, including long term reliability:
Changing C963 from 2200uF/10V to say 4700uF/6.3V additionally improves Vee stiffness and stability. Often just doing that without the R961 fix reduces the skipping problem, clearly showing Vee is the culprit.
The 5V output is invariably a bit high, around 5.2 - 5.3V. It can be trimmed closer to 5.1V as stated in the manual by soldering a 27k resistor in parallel to R956, on the bottom side of the board. This is important because the laser head is supplied with this voltage, so overvolting is not at all desirable here. The 6V voltage (incorrectly labeled as 7V in the manual!) is not that critical and can be left alone."
I sure would like to know, as my X707ES still works most of the time, and the symptoms listed here fit mine to a "T".
Just hard to find a "competent" tech to look at my unit.
I also have a spare (X339ES) in mint condition for when I have to.
Comments welcome and appreciated, as I, and all of us here, need help.
Cheers
