FS : ELNA FOR AUDIO 12000uf 63V
If you are ordering caps, I would suggest stocking up on these PSU pcbs. I have been using one to reform caps and have soldered/de-soldered onto the cap traces about a half dozen times with no ill effects whatsoever. Alot of the ebay stuff, one de-solder and the pad evaporates. Quite the deal at a buck apiece.
This is PSU PCB sell in Indonesia market
After 1 batch production, sometime they change Model
That board is the same I received.
Dimensions: 85mmx120mm
Caps: Up to 40mm diameter
Lead: 10mm for snap-in, up to 20mm for radial lead type
Rectifier: Lug type bridge or in-line (vishay powerbridge style) lead type only
As I said earlier, pads take multiple solder/desolder cycles with no problem, highly recommended if you ordering caps, grab a bunch.
Thru hole spacing of 7.5mm on the Vishay Powerbridge style bridges...
Hi RCruz & Evette, very sorry for late reply
2 years ago audio number one but now family is no one
cause the kids can make a big complain hahahahaha
i have some caps in my stock price for caps @ US$ 6
if you want big quantity i got some supplier stock it
For PCB do you want for 6 caps (sometime available)
or 4 caps (always available) i can let you know how
to make them better than ( i think some people try )
@ US$ 2
btw there is some one live in canada mail me
but his email gone when i manage email via BB
very sorry i didnt mean it loose your mail
Thanks a lot dread pirate for help everybody here
i always go to this forum everyday but if i read a
thread like F4 power amp, reference dac, MPP, etc
and another forum DTQWT by troel gravesen
it was looks like they eat my brain little by little 😀
Best Regards
@ US$ 2
Hi, Jeffry
I got a bunch of those Elna caps from you sometime ago and like them a lot. It will be perfect if you can get me a few of those 6 cap PSU PCBs. Please post when you have them available. Thanks!
@ US$ 2
I would like 4 caps and four PCB's (4 caps type).
Please PM me 🙂
Ricardo
Hi, Jeffry
The PCB Available now
They are 6 caps PCB, should be for 30 mm caps
but with your skill, a little bit diy the 35 mm caps
can solder here (Push, Drill, Bent the wire, Karate, ETC)
For 4 caps is out of the stock now but you can use this
4 circle for 4 electronic caps, 2 circle for bypass caps
1 PCB @ US$ 2
1 Elna for audio 10.000 uf 80 v @ US$ 6
1 Elna for audio 10.000 uf 63 v - No Stock
1 Nichicon KG 4700 uf 50 v @ US$ 1,5
1 Diode Bridge 3510 Motorolla - Chinnese @ US$1,5
1 Diode Bridge 5010 Motorolla - Chinnese @ US$ 2
1 Bypass Caps K75-10 or 24 2 US$ 1,5
1 Bypass Caps K73-16 US$ 1
1 Bypass Caps Vishay / Wima / Ero US$ 1
As a lot of question asking in my PM
Solder PSU with caps - Almit Japan US$ 2
Solder PSU with caps - WBT US$ 5
Solder PSU with Mundorf AG/AU US$ 5
you can add 2 LED with resistor std for quit US$ 2
you can add 2 LED with resistor vishay dale for quit US$ 2
you can add cooper wire to make it great US$ 3
You can add feet US$ 1 (for diode bridge go to bottom chassis)
You can add output cable US$ 5 (2 - 3 colour x 0.5m)
Best regards
1 PCB @ US$ 2
Best regards
Hi, Jeffry
Thank you for the info. So the 6 cap PCB available now is built for 30 mm caps only, please confirm. Are those bypass caps Russian? Lastly, what are those "solder PSU with caps"? Can you post more pictures (the picture on the 6 cap PCB is kind of blur) please.
Almost forgot, what is the shipping cost for the PCB to Canada?
Thanks!
Hi, Jeffry
Thanks!
hi Lo Tse
i didnt build pcb my self, they are available in indonesia market
for k73 and 76 are russian
shipping cost depend on the weight, what is the item you order ?
some buyer order with caps and everything solder to PSU
best regards
