Ultra Simple Class D
good day guys, I'm planning on building this amplifier, one thing that bothers me is how to make the inductor coils. you see, I don't have an inductance meter, can anyone help me on this, i'd also like to know if I'd be able to use my toroidal core ? thanks mates 🙂
EDIT: sorry, the pics are soo big, heheh my bad
cool pictures . about inductance try to use mini ring mini Ring Core Calculator it has most major cores but not all . i hope it will be of help to you . it is a very useful tool
if anyone has a link to a better program pls do post it's link.
Mini Ring Core Calculator Software Informer: Screenshots
thanks to stewin
i have not built this amp but the below link in post #139 i have tried and tested it 😎 😎
http://www.diyaudio.com/forums/class-d/205654-ultra-simple-class-d-14.html#post3091551
it is diferent with post #139
in this shematics and pcb the zener diods is diferent side
what?
which side is correct stewin?
can i use class d amp for HPF band like 6975 pioneer or tiuter?
thanks
what about the protection DC and OCP?
can you please send to me pcb files?
i am using protel dxp.
do you have it?
mr cpx try to hellp me but i can not do that beacuse i can not to find component and i dont have good knowlage.
thanks to cpx hellp.
thanks to you mr stewin.
Hi.
I currently am building that amp too, and i've got two questions:
first, concerning the amp itself: is a T20-52 core suitable for this one as output filter?
I guess noot, but i am not sure ... or would a T34-26 be suitable?
second, will this amp interfere with a SMPS mounted in the same alu casing, running with 50kHz? there is about 25mm space between the amp and the SMPS.
thanks in advance 🙂
