Hi Harrison
My transformer has arrived from Trade Me ( NZ E-bay ), it's a bit bigger than I thought it would be
1300Va
Output 1, 31volts @ 17.5 A
Output 2, 31volts @ 17.5 A
Output 3, 31volts @ 6 A
13.8 Kg's
No loss of power here ....but will need a soft start for this puppy!
That puppy is huge, sorry meant bull dog
Not sure, how do you test the " no load input VA"?
Measure AC current and ACV with multimeter, V x A = VA.
The KILLAWATT a great power meter.
P3 - Kill A Watt
Thanks WSJ
I put a clamp meter on the phase last night and got,
0.7A x 230v = 161VA
Does that sound low?
I do know that when I fired it up on the variac without winding it back to 0v first it blew the fuse straighht away! hence the soft start!!
I measured my ALESIS RA150 amp at 66 VA, no signal.
4 ohms: 75 watts RMS per channel.
For the size of you trans, 161 VA is not too bad.
At my power cost, 161 VA would be about $12 a month running 24/7.
Dagwood, that transformer is physically quite massive and could put out huge magnetic field that could induce hum into everything close.
It may be worth considering mounting it outside of the amplifier in its own enclosure and you can build the power circuitry remotely from the amp.
I would check the spec on that trannies but I do believe anyone of the mje15030====series will work. Regards Evette
Joe,
Are you shure that's a TO220 case the MPSW42 is a TO92 case?
- 1DIFFQC amplifier
