nope
we are not forgetting anything
it's always possible to feed main channel with F6 , while boosting any other channel with F4, from F6 output
With the speaks I am talking about, the one will do them all
Who said these were my only speak, anyway. I can quit anytime, although now I am under direct orders tha nothing can come home unless it is finished. Yeah Right!
I think it is possible that my Phono or DAC could drive F4 directly with these, although a lower DF might be on order. Semisouth F2 anyone?
........ Semisouth F2 anyone?
tea-bag, he would take his F2J on the lonely island....😀
I have been doing some serious listening to my "improved" Teaser-6 and it now brings back memories of some of the old tube amplifiers from my past in the 50s and 60s. Since Nelson described it as "basically it's a classic" I suspect I am listening to something similar to what he intended. 🙂
Excellente! What do you think? Keeper? Isnt interesting how different the sonic signatures of amps can be. Have you tried tweaking edginess out of f5?
I suspect that I will switch back to my balanced F5 after a few days. One idea would be to find an antique cabinet used for the best radios in the 30s and 40s and equip it with an F6 and a decent 12 inch speaker.
I have not really played around with the P3 adjustment on the F5 other than to null the 2nd harmonic. I wouldn't say that there is much "edginess" with the F5, other than perhaps needing a little high frequency rolloff.
F5 has a lot of capability. If you have not heard a mulitple pair version, you have notheard the F5, IMO. At least this brings it into line with my listening taste. I have adjusted it a for a little more 2k, but not much. Try the BA3.
ZM: What is the material of that grill and how long does it take to get it hot enough for pancakes?
Baaaaad Papa !
........ just deleted 3 lines of typed text ; there is no use of it .......
boyzzzzz'n'girliez - take a good look at these two horizontally drawn resistors
edit : inserted picture , with two horizontal resistors
Off Topic, please excuse -
For those contemplating to "soften" the F5 towards something like the proposed sound of this F6, changing the resistors for Rhopoints for the crutical positions, TRW/PRPs for others and the Isabellenhutte PBH for the power resistors is a complete "gamechanger" - pity the darn things cost so much, plus the "necessary" upgrading of power supplies.
JH, The natural sound of the F5T circuit with even one set output's is worth noting. A bit calmer and more controlled, as discussed elsewhere.
I've noticed the most changes with F5 in general by changing the signal resistors, input and gate.
material is plain stone 😉
it must not be sandy - meaning - it can't have sand layers , because that sort of stone will not last long
you must be careful during first fire - start with small amount of wood and add slowly ; if stone live that without cracking , it's most probably good
some sort of support underneath is wise to have , so it leaves only thermall issues to stone
wrote that several times already , in all sorts of threads in Papaland
before heating it for next BBQ , clean it with wire-brush and some other sort of hard brush
when hot , add grease or oil ;
regular time for full temp - less than you need to heat up casted iron BBQ
Pita bread?material is plain stone 😉
hm.... Pita means few things to me , but I'm not sure that we are thinking of same
please explain ..
please explain ..
- F6 Amplifier
