Every dipole speaker can do this where
a. The sub is "separated" from the rest
b. the sub goes up to your desired F.
To get to the Schröder F (or a little beyond) with reasonable output you might require already 2 drivers per side.
Yes but my point was that it's not done. Being able to adjust mode coupling is one of the biggest advantages of a dipole but it's not utilized. Recognize any of these dipoles?
Markus,Again, the topic was LF. One can make the dipole null "point" in different directions by rotation. This shouldn't change the direct sound significantly but it will alter the way the dipole couples to modes.
I have done that with my earlier dipole speakers. Significant altering of modes will only start if you rotate the dipole at least ~45° against the mode axis. You don't want to switch off single modes, but probably want to attenuate one mode and raise another mode at the same time. Inevitably that led me to a 45° toe-in of the LF dipoles - every time. And it did change the direct sound significantly!
At 45° an ideal dipole should be 3 dB attenuated compared to 0°. If you keep the mid/high part of the dipole at 0°, you have a matching problem. JohnK discussed that at Power matching
Again the easiest way to solve it is to rotate the mid/high part of the dipole too - which has some advantages in itself. In the end I never had a convincing reason to rotate the dipole LF part independently from the upper part.
Rudolf
45° is a lot, probably already too much. Did you try different source locations and rooms?
I have four separate dipole woofers, where two are located at the sides and almost 90 degrees rotated. This concept works very very well indeed. The resulting response is smooth and free from dips and bumps from room modes.
Mainly one room, but dipoles located at the long wall and the short wall. Measured results were different of course, but the conclusion the same for both installments. You find measurements and a discussion (in German) of the short wall version at Dipole und Kontrolle der Raummoden, Lautsprecher - HIFI-FORUM45° is a lot, probably already too much. Did you try different source locations and rooms?
Well.. sort of. They are placed close to the front and side walls actually.
Found the floor plan. Looks like you're listening with an opening angle >60°?
Since there is discussion about position I thought I would post this quote from one of my web pages:
Dipole:
Consequences of source position (independent of orientation):
There will be no contribution to the in room SPL from an axial mode aligned with the dipole axis when dipole is centered at a pressure anti-node (velocity node) for that mode.
Additional consequences due to directionality (orientation):
There will be no SPL contribution from any mode in the direction orthogonal to the dipole axis.
Monopole:
Consequences of source position:
There will be no SPL contribution from a mode when placed at a position where that mode has a pressure node.
Additional consequences due to directionality:
Being omni directional, a monopole has no consequences arising from directivity.
Cardioid:
In general a cardioid is not limited by position alone with regards to modal contributions to the SPL.
There will be no SPL contribution from a mode when placed at a position where that mode has a pressure node if it is also oriented such that the mode is orthogonal to the axis of the cardioid.
These are under idealized conditions but give a sense of why different woofer formats behave so differently. Also, recognize that it is a two way street. A woofer may excite a mode very strongly but it will have no effect at the listening position is the listener is sitting at a pressure node for that mode.
Also, regarding separating the main speakers and woofers, that was one of the features of the Mini:
Dipole:
Monopole:
Cardioid:
It has been changed somewhat since then. The listening angle for the main dipoles is close to 90 degrees, and the side woofer towers are at almost 90 degrees angle from the listening pos. The woofers are closer to the walls as well.
Thanks Rudolf. Did you also test monopoles? That room looks really ugly (acoustically). Looks like John's right and the solution is not in the source type.
[...] the idea that you can plot a dipole woofer down anywhere and get superior bass because it excites fewer modes just doesn't bear out.
I think the rotation is not the biggest advantage but the biggest advantage is the cleaner impulse response dipole produces in a small room within the first 100-200 ms.
For the input of this:
Dipole response:
Monopole response:
Source type is the biggest effecting factor, but you must use the relevant metrics to realise this.
Since, if you take old fashioned long time window FFT the difference between monopole and dipole gets smaller. In that case they are very different but it's getting harder to decide which one is better.
Elias,
Is your software available anywhere? If I had it and could run it I might be interested in reconstructing my CRAW woofer to look at all three: Monopoles, dipoles and cardioid.
No. Haven't had a monopole woofer for years. But since you have both types at hand now, we finally can rely on your test skills 😀Did you also test monopoles?
In fact it is ugly looking - but not acoustically 😉 With better positioning of speakers and listener in the room (a la john k...) the response is a lot better now.That room looks really ugly (acoustically).
Right and wrong imho. Of course you can make a dipole out of two monopoles with inverse phase anytime. In that regard source type doesn't matter. But ...Looks like John's right and the solution is not in the source type.
there have been quite some people asking me for my opinion/advice WRT a dipol bass solution in their room. If they were already pleased with their monopole solution and just wanted to satisfy their curiosity about dipoles, final reactions where mostly like this: "Now I see, what this fuss is all about, but I don't really see enough reason to change what I already have."
But there was another group of people who had moved their monopole (sub)woofers or speakers to every possible position in the room and never found a satisfying sound. Without any exception those people were incredibly happy about the change, which the dipole made for them. Sometimes the solution is in the source - at least practically.
Rudolf
In my case I do not feel that I have a need but haven't looked into this further.Yes but my point was that it's not done.
I once had a standalone 12" H-Frame that I had been pushing throughout the room and turned it as well to check how the sound changes but I did not do measurements. Anyway, the sound did diminish noticeably at the listening position when toed in too much.
That sounds like a nice offer !Elias,
Then you can add one to the list. That was true in my old flat.But there was another group of people who had moved their monopole (sub)woofers or speakers to every possible position in the room and never found a satisfying sound. Without any exception those people were incredibly happy about the change, which the dipole made for them.
How convenient, isn't it 🙂 Slight delay though, my carpenter is on vacation.
Rudolf
Maybe they did something wrong 🙂 Double Bass Array (DBA) - The modern bass concept!
What I'm after is beyond monopole/dipole but about low modal ringing and smooth frequency response.
In those cases the dipole solved the problem with the least added amount of material and man hour. Effectively the better engineering solution 😛Maybe they did something wrong 🙂 Double Bass Array (DBA) - The modern bass concept!
Yeah, finally another breakthrough brought to us from the Swiss 😀What I'm after is beyond monopole/dipole but about low modal ringing and smooth frequency response.
But honestly, every fresh look at the problem is laudable.
So the imulse has to be in the form of a wav file? That's not too convinient. All my impulse data is in the form of text files which are generated using an MLS burst.
- General Interest
- Room Acoustics & Mods
- Measured monopole and dipole room responses
