Discrete Opamp Open Design
diyAudio Member RIP
Joined 2005
How about CPC3730 from C P Clare? With that and some 140V transistors this could be the front end of a 100W amp.
Ahaa, didn't realize Clare sold individual parts, a logical move though, based on the optos stuff. That's reassuring that we have at least two manufacturers of depletion mode DMOS.
EDIT: Also the geometric mean of the threshold voltages listed is 2.5V, a bit higher than the other parts.
Good point, BTW Infineon has some too, SOT23 and very low capacitances.
Rather than answer questions piecemeal how about I put a device by device description in the articles section, this is a holiday weekend I might have some time.
Scott, when you do this for #1397, could you also explain the reasons for various choices? I would much like to know the reasons for
  • the fancy output stage compared to simple Class B as in 990
  • why FET i/p instead of simple BJT in your rehash of 990
Just tried something else in my version of SW-OPA, looking at PSRR. At 20kHz, only a bit over 15dB on the -ve supply, 30dB on the +ve when working at a gain of 20. So an extremely well regulated supply will be necessary for the circuit as is ...
Frank
Frank,
dadod's version sims at about ~-25db at 20KHz on the negative side with your 20K/2K feedback values. Switching to K170/J74 models for the front end @ 7mA, everything else otherwise the same, brought it up around ~-31db at 20KHz. Low frequency is about -89db for the LSK389/J109 with the knee at about 65Hz. The K170/J74 was in the -96db range with the knee around 70Hz. High side PSRR is better.
All based on the LTSpice sim of course… Anybody else get similar numbers from it? It would be nice to know it works the same in multiple locations, even if just in the sim at this point.
Dave
And of further interest, a member PM'ed me about a breadboard he's already knocked up, and his PSRR figures, measured at lower frequencies, correlate beautifully with what the sim predicts ...
Frank
PSRR is something to look at and there could be some tweaks. I would expect non-cascoded inputs to be fairly sensitive to source impedance mis-match. Welcome to the design process.
EDIT- OK we need to track down the discrepancy, the very first circuit (all N flavor FET's but input cascoded) shows me flat -100dB RTI on both supplies out to 20K.
Disabled Account
Joined 2008
PSRR
This is what I'm getting when simulating Scott's BF862 circuit with the buffer.
I have also attached the schematic I'm using, showing how I do the PSRR simulation. Maybe I'm doing it wrong?
Stein
  • NEG PSRR.pdf
  • POS PSRR.pdf
  • SW BF862 with buffer.pdf
