Pass F5 Pair (Spuds)
Were those sitting on the doc of the Bay? (from e ba y)?.
I bought some from there, and i like em!.
I love the output devices spacing, (on a 35cm sink).
Puts your input and outputs close to rear panel too.
You can tell Papa designed them😀.
Indeed they were. Took about a month to get to South Africa, but worth the wait.
I have an order in for most of the components, so hope to get started on them soon.
DC offset is under 1mV on both channels. 😎
At full bias (0.59V) DC oscillates within 1mV. 😎
AC ripple/noise on both channels is under 1mV with input RCAs shorted. 😎
Plays like a dream. 😎
That, and it's ghostly silent. 😎
it will be much more efficient if cut in two halves per length , then positioned with fins vertical
with piece that long , you have maybe just 1,3 of capability of one half
also - you need dome clearance between fins and base on which is heatsink standing
