Hello nazirdigi,
Very nice!! and I like your fan controller, can you share???
PCB for fan controller.
This is perfect Mr. Mile
Many thanks for sharing,what is the PCB size?
Wiljj78
oh wow that look really nice and neat good mister olafk congratulations!
vargasmongo3435
vargasmongo3435
Was fun to build it.
It has a fresh and transparent sound, crystal-clear highs and a powerful tight bass. In my opinion, very suitable for hifi.
lookin´ good!
You have done a slight modification of a pcb to adjust pins for multiturn trimpot and wider traces that lead speaker output i´d say... Nice work really! Great!
Hi All,
I have finished my first AX14-module. It has nice clear and transparent sound. I like it!
regards, Olaf
Hi All,
regards, Olaf
Nice work
vargasmongo3435
I hope you have already the PCB which you are working for AX-14. Olak have done it with parallel input capacitor.
Regards.
Rey
schematic for ax-14 TEF version ??
For TEF version use AX20 schematic
@kan Daman, mohon bantuanya... gimana cara mengecek teg bias pada ax14.dengan menggunakan avo digital,bagian mana saja yang perlu di cek.untuk colok + / - pada avo di arahkan ke mana saja.dan berapa teg bias standart pada ax14.coz mau tanya langsung sma kang Mile gak bisa bhsa inggris. hi..hi..hi.. bisanya cuma Teng yu...
Translated by Bing,
@ kan Daman, please bantuanya .... How do I check the bias tag on ax14. using avo digital, which parts need to be checked. to plug +/-on the avo in navigate to anywhere. and how much bias tag standard at ax14. coz want to ask kang high school Mile direct gak bisa bhsa UK. hi ...hi ...hi ... usually only Teng yu ...
Translated by Bing,
koming, please can you post in English as per the forum rules.
http://www.diyaudio.com/forums/site-announcements/167561-diyaudio-rules.html
Apex AX14
Hi Alex,
Good to see you here. Can you render a PCB of Apex AX14 with a size of Vishay RN60 series resistor (L-(8.74 ± 0.79mm) W-3.68 ± 0.38mm) and a parallel input capacitor (Wima 4.7uf 50V 5mm pitch). Olafk has done his own PCB. I have done APEX AX14 with his PCB and the sound is very good🙂.
Regards.
Rey
Hi Alex,
Regards.
Rey
apologize in advance if my english is not good. hopefully can understand and willing to help me.
This my apex ax-14...
(help in correction and give an explanation.)
problem if the volume at 12 o'clock opening his voice so hoarse / burst like over input and output are not able to handle. but if the volume is open until 10 o'clock sound awful. mid clear, crisp treble but not much bass.
Please HELP!!!.
and how to check the bias and dc offset on the ax-14. any parts that need to be checked. to plug in + / - at avo directed to anywhere. and how biased standard ax-14. thanks and sorry if many questions.
Please HELP!!!.
Please HELP!!!.
Output transistor must be mounted on heat sink even for testing.
Place 100R/10W resistor instead of fuse.
To check DC out: Connect input GND to PSU GND and place your DMM test probes black to PSU GND and red or positive probe to Speaker out (reading should be in mV DC).
Bias setup: Place your DMM negative probe to Gnd. and Positive to R33/5W or Emitter of 2SC5200/2SA1943 and adjust 1K trimmer to 15mV DC.
Hope this will help…
Translated by Bing,
aku pakai tegangan 45VDC mudah2an gambar bisa membantu.
- 100W Ultimate Fidelity Amplifier
