Frank,
many thanks for sharing your findings.
Stefano
Stefano
No, any electrolytic or solid polymer, OS-CON and the like, will always be safe, even when paralleled with a film cap. Tom doesn't quite agree with me on this, but I suspect the bad behaviours he's come across are because of film caps at a distance from each other, i.e. the lead inductance between the caps comes into play.
Always remember that ESR is not a locked in characteristic, it varies all over the place depending upon just about everything, so don't get hung up on precise values ...
Frank
Andrew and Terry our sincere good wishes to you both and appreciation for spending so much of your time on this thread.
I am saying 110 for the sake of talking, I have not measured any voltage on my home.
Maybe I need to do a SMPS, no chance of droop
Yeah , but bad sound .....🙂
won't be today and probably not tomorrow either.
Going back into hospital to sit with my Dad.
All the best with this ......
Bypassing electrolytic caps. Easiest solution is more electrolytic caps.
Well, a positive combination occurs when:
Case 1: The electrolytic is so high efficiency that it can overcome the film cap. There's most of the Os-Con and solid polymer examples.
Case 2: The value of the film cap isn't large enough to fight with the electrolytic. Like matching woofer to tweeter, the lf of the film cap is chosen to sum with the hf of the electro for level response, neither underwhelm nor overdo. Excessive overlap/overdo makes gross distortion unless the film cap value is small enough to avoid that problem.
Case 3: The film cap has poorer efficiency and could never fight with the electrolytic. Classic example 4.7uF Cerafine with 22nF polyester dip cap.
Case 4: A tiny value electro (Nichicon makes bypass electro and they're super easy to use) or a film cap with a series resistor. These are used for a longer gentler taper and decreased matching problems.
But arbitrary 100nF polypro bypass caps is Russian Roulette for the deaf. If the overlap of the hf from the electro sums greatly with the lf of the film cap at two different timeframes, the resulting gross distortion is both far louder and less useful. It will take much extra effort to sum level and that takes exploring values other than 100nF.
I'm mostly agreeing with Tom. Bypassing electrolytic caps with film caps is possible but very time consuming to do a nice job of it.
It isn't only SMPS that can cause a dulling. Linear unregulated can do it too, especially if the umbilical cable is zero length. A general fix could be run the predrive on regs or. . .
Perhaps Halfler already answered this question so many years ago with an economical sort of "dull-blocker"? Here (attached) I've attempted to apply diode drop to the predrive like Hafler would do. Had this been an LM1875 (with 330u caps on the pins), I would have applied a schottky drop for both v+ and v- to the entire chip, due to lack of separate predrive power connection. However, in the photo below, TDA7294 has the predrive power connection available. TDA7294's output stage is at unity, so the 470u is undecided and could be up to 3,300u or more. Due to vexing pinout corrupting PCB layout, the design below is for use with point-to-point via pinbend (rails horizontally across the chip, v- pins bent all the way to chip face, v+ pins bent half that far, ground in the middle, rails across simply) which is much easier than it looks and takes only minutes. The design is not yet finished. It awaits a bit better filtering, perhaps a different NFB cap arrangement via mixer if needed, exploring the worth of anti-miller-comp since the normal settings are sealed away inside, and other explorations and fine tuning which is not yet done.
Caveat: There's more fake TDA7294 than real, and the fakes don't have working protection or high voltage tolerance or high load tolerance, so if you bought your chip from the market, nearly guaranteeing a fake, use an output cap or other speaker protector and use lower voltage and/or lighter load. Typical tweeter crossover protection is insufficient unless an additional cap is put series to the negative. I'd rather we use Authentic TDA7294 from ST's listed vendors, such as Mouser--Those are real and the protection circuits work.
But, the point is. . . have a look at the power circuit. Did I do it like Hafler?
Daniel,
Why are there smaller bypass caps (3.3nF) upstream of the diodes instead of at the supply?
I've never gotten away without paralleling caps it just seems you can't do it blindly. The net result needs to a low impedance which necessitates parallel capacitances but controlled to not have (sharp) resonances.
Hope this helps
-Antonio
Hope this helps
-Antonio
The key phrase to add here is "at high frequencies", audio and above. This is where the killer action happens, the amplifying circuit has to be be able to draw sharp, as in equivalent to high frequency, transients of current with minimal glitching of the voltage rails. Otherwise, everything suffers, especially feedback, because it has to be able to work at high harmonic frequencies to be able to snub out incorrect, distortion harmonics. Resonance peaks means that the power supply will effectively work poorly at a possibly critical, high frequency, by having too high an impedance at that point, and that's what you have to work to avoid ...The net result needs to a low impedance which necessitates parallel capacitances but controlled to not have (sharp) resonances.
Frank
Frank
Agreed but it's really not that hard to design and verify that you have achieved your desired impedance (at least upto 10MHZ).
The hard part is determining the desired impedance.
Hope this helps
-Antonio
Hope this helps
-Antonio
Huuhh? Desired impedance is zero, at all frequencies, simple as that. Then no matter how much noise is injected into the voltage rails, or current draw, they're rock steady in value. If you don't like the sound of your amp when functioning in this enviroment then there's something wrong with the amp ...The hard part is determining the desired impedance.
Hope this helps
-Antonio
Frank
Frank
It's getting just a little confusing, maybe. Resonance is a low-impedance effect. "Resonance peaks" might be easy to misinterpret. In a frequency response plot, resonances are peaks. But in an impedance plot, they would be deep, often-sharp nulls. Resonance occurs when the capacitive reactance and the inductive reactance cancel each other, leaving only the series reistance, which is as low as the impedance can get.
So the best way to think of it might be "resonant dips" and "impedance peaks". But even Henry W. Ott alternates between calling the peaks "impedance spikes", "resonant peaks", "resonant spikes", and "anti-resonance spikes".
Resonance is often a good and helpful effect. For digital decoupling caps, where all of the edges for a particular chip usually have the same rise time (for the current pulses that are demanded by the pin being decoupled), and thus all have the same equivalent dominant frequency
f = 1 /(π ∙ trise),
the best you can do is to have the decoupling network be resonant at the needed dominant frequency, since that will make the current response of the caps be able to be bigger and faster, more easily and more quickly, which translates to them being able to supply the needed current with better time and amplitude accuracy, with the smallest-possible disturbance of the power rail voltage.
And where decoupling needs to cover a wider range of frequencies, sometimes people attempt to choose multiple values of parallel caps so that their resonances are spread out over the needed frequency range. Problems are usually part of the result, because the multiple capacitors interact to cause high-impedance peaks in between the resonant dips, where high impedances are not wanted.
The resonance dips are usually "a good thing", in a decoupling or bypassing context. They "swallow" problem frequencies, optimally, if located there. They produce current transients optimally upon demand at frequencies where they are needed, if located there.
The impedance peaks (the "anti-resonance" points produced by interactions among multiple C values in LCL networks) are usually "a bad thing". If they are, say, 25 dB-high peaks, then noise and whatever else is around will be 25 dB higher in level, at those frequencies. And if current is needed at those frequencies, the response is very poor. And if an amplifier's high-frequency power rail feedback has content at an impedance-peak frequency, the amplifier would be likely to oscillate at that frequency.
There is usually not much of a problem if the paralleled capacitor values are within a 2-to-1 ratio, because then the spikes usually fall within the dips, greatly reducing their magnitudes. The severe problems occur mainly when the capacitor values differ by an order of magnitude or more, such as when paralleling small-value film caps and large-value electrolytics.
Adding ANY capacitor, anywhere, is always actually the addition of an LCL network, because there is ALWAYS inductance in the capacitor and in its connections. The resulting LC networks ALWAYS have resonant frequencies. And multiple parallel LCL networks (i.e. any two or more paralleled capacitors of two or more different values) ALWAYS also have antiresonance impedance-peak frequencies, between their resonance-dip frequencies.
Tom
With that schematic you're potentially in trouble. That's because the substrate on the TDA7294 is connected to pin8, not to pin15. You can verify this with a multimeter - pin8 to case shows a short and pin15 to case doesn't.
ICs are designed to have their substrate at the most negative potential in the circuit - apply forward bias and you're likely granting an exit visa to that magic smoke. How do I know? I tried separating the supplies of pin8 from pin15 on the first breadboard I made with this chip. Do it at your own risk 😀
Part of the capdiv noise trap, and those 3.3nF polyester are small enough to prevent the other caps from ringing and knock some noise off the power cable.Daniel, Why are there smaller bypass caps (3.3nF) upstream of the diodes instead of at the supply?
Anyway, so tiny that there's much less chance of causing trouble.
P.S.
That design is not yet complete. Bypass cap for all 3 identical models of 220u shown is easy and quick to determine at the NFB location, and if you keep it simple, same size bypass cap works for the other two 220u caps (if same model). Nobody will make a horrifying choice if they have to listen to it first at the NFB cap. But I can't specify a bypass cap value unless I also specify the exact model of electrolytic cap to use with it.
P.P.S.
3.3nF at the power board? Those are so small--Only way to have that bandwidth intact available for the amp is put 'em on the amp board.
Thanks!With that schematic you're potentially in trouble. That's because the substrate on the TDA7294 is connected to pin8, not to pin15. You can verify this with a multimeter - pin8 to case shows a short and pin15 to case doesn't. ICs are designed to have their substrate at the most negative potential in the circuit - apply forward bias and you're likely granting an exit visa to that magic smoke. How do I know? I tried separating the supplies of pin8 from pin15 on the first breadboard I made with this chip. Do it at your own risk 😀
I've seen some designs using the diode drop with that chip; however, it is both experimental and optional.
Here's one simplified without the diodes (attached).
This one doesn't have "experimental" status, except that it needs the RF filters added. The amp shown plays well.
As a cost of subtracting the diodes, the tone will change depending on power supply arrangements and umbilical cable length.
However, the diodes (this time schottky) can be installed to the spots marked +30 and -30. 😀
As regards the depth (or height) of resonances due to these effects, simulations are a poor estimator because they don't model skin and proximity effects. Hence Q's in practice will turn out to be lower than Q's in theory. I've given up relying on Spice where inductors and high frequencies are concerned, other than for the most basic of results.
Incidentally I recently discovered that 50V 1uF X7R caps when biassed near to their maximum voltage lose more in ESR than they do in capacitance. When biassed up the capacitance is about half the nominal value but the ESR goes down by a factor of 4. The 1206 1uF shows a highly impressive 3mohm ESR on Kemet's capacitor simulation software. I plan to try a few in parallel on my next chipamp build.
There's no reason I know of to take out the diode on the positive rails - no chance of blowing it up there 🙂 I'm working on a TDA7293 design at the moment and I'm going to run the positive driver pin (pin7) on a boosted, linear regulated supply. I suspect (though have no evidence) that positive PSRR is going to be better than negative so I'm borrowing a leaf from Klaus (KSTR)'s book here in referencing signals to the -ve rail. It would be cool if STM published such specs as National do on the LM3886 - that part's positive PSRR is very impressive.
At least I'm in good company ... 🙂. That said, using "impedance peaks" may help reduce confusion out there, so I shall aim to consistently use that term forthwith. But, the effect is still due to a resonance behaviour, between the L and C characteristics of separate parts, in the "anti-resonance spikes". If there were no L in the picture then these spikes would not occur, no matter what C values were in parallel; resonance is both a low and a high impedance behaviourSo the best way to think of it might be "resonant dips" and "impedance peaks". But even Henry W. Ott alternates between calling the peaks "impedance spikes", "resonant peaks", "resonant spikes", and "anti-resonance spikes".
This is where I part ways with you, Tom, sorry. You'll have to show me with LTspice, say, where paralleling an electro and a film gets you into trouble. Note the thread, Mundorf M-Cap Supreme as bypass cap? where I talk at length about this stuff ...And where decoupling needs to cover a wider range of frequencies, sometimes people attempt to choose multiple values of parallel caps so that their resonances are spread out over the needed frequency range. Problems are usually part of the result, because the multiple capacitors interact to cause high-impedance peaks in between the resonant dips, where high impedances are not wanted.
Frank
Frank,
Stefano
Frank
Frank,
I am only one of many who disagrees. <grin>
This should be required reading:
http://www.diyaudio.com/forums/power-supplies/106648-paralleling-film-caps-electrolytic-caps.html
It can only cause problems, if PSU reservoir caps are paralleled with small film (or other types of) caps:
1. At worst, and guaranteed usually, it will create impedance peaks (aka "resonance peaks") that could greatly increase the amplitude of high-frequency noise and harmonics.
2. At best, it will acheive nothing.
The function of the caps, there, is to release current when the load demands it. Any high-frequency or fast rise-time currents that the load needs can't be provided effectively by a film cap located by the PSU reservoir caps, because of the inductances of the power and ground rails.
Any small caps belong within a millimeter or two of each active load's power rail connection, where they might actually be able to do some good.
Tom
Simple, perhaps, but how practical is it?Huuhh? Desired impedance is zero, at all frequencies, simple as that.
OK, round 2, 😀 ...Frank,
Electro's have low Q because of their very nature, their construction. That is, if you look at a curve of impedance with frequency for such it will alway look like the bottom of a bathtub, which means low Q: high ESR for the value of C and L of the unit. And that relatively high ESR will always damp any resonance with respect to any adjacent capacitor, film or electro.
But 2 high Q cap's next to each other, film say, is asking for trouble, if you get the values wrong, because the ESR of either is insufficient to damp the resonance between them.
Yes, the bypassing needs to be where the transient current is required, within millimetres of the part, for the real benefit to be felt.2. At best, it will acheive nothing.
The confusion is in part where you think the power supply smoothing caps should be: in my world they should also be within a tiny distance of where the current actually does its work, not on the other side of the amp, because it's convenient to have them there, or it looks nice ... 😀
Frank
Of course not possible, I was just quibbling with the term, "desired impedance" - this should just be as small as possible, or else do the design and simulation work to find out how much you get away with it not being "perfect", i.e., zero ... 😀Simple, perhaps, but how practical is it?
Frank
- Power Supplies
- Power Supply Resevoir Size
