The simplistic Salas low voltage shunt regulator
diyAudio Chief Moderator
Joined 2002
Its the Vgs barrier of the output Mosfet and the Vbe additions of the mirror transistors. When running a high power Mosfet at 200-300mA its Vgs is sleeping enough and it can get you near 5V when compromising the mirror for voltage, that is why I recommended 7V floor, to have room. With low Vgs TTL Mosfets things change for margins.
Joined 2006
Ok.. it needs a 7 V floor... I use 10v floor... but it can work outputting 5v, you just need to input 5 + 7 = 12v to have enough headroom right ?
Joined 2002
P.S.
Vin-Vo is another story than VoMin, follow the normal practice with such regs. No less than 5V Vin-Vo not to goof up the CCS, 10V projecting for good measure against Tx & mains tolerance. Although you may find that this class of regs can regulate very near to Vin=Vo (one Vbe dif) the CCS will lose steam.
P.S. Kazuo-san may post to discuss it & clear the assumptions?
The Sabre DAC seems to be working well for me. But I have only poor oscilloscope. It is possible that I can not observe osc.
When I move the position of the reg. board, it may sometimes oscillate obviously.
Honestly saying, I have no confidence the value of Zobel. I would like to wait for diyer's suggestions.
Attaching is the latest version.
