Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Hi Ian,
Please include these to waiting list
N01. cddumat 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
N02. spm I2S FIFO,Dual XO Clock board,S/PDIF Interface Board,2x SMT U.FL,8x 6",4x 12”,I2S backdoor KIT, 2xXO Adapters lot of 5,2xBIII adapters,2x SMT connector package
N03. Regland - 1*I2S FIFO Kit, 1*Dual XO Clock Board, 1*S/PDIF Interface Board, 2*BIII adapter
N04. AR2 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 2 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 2x Additional BIII adapters PCB, 2x SMT connector package for BIII adapters
N05. vertigovh72 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Universal SMT XO Adapters KIT lot of 5
N06. sidiropa 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Universal SMT XO Adapters KIT
N07. Pinnocchio 1x I2S FIFO Kit, 1x Dual XO Clock Board,
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N13. new waiting list no.
1 * I2S FIFO KIT
1 * Dual XO Clock board
1 * S/PDIF Interface Board
1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
Adding myself to the waiting list
1 * I2S FIFO KIT
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
Please adding youself to the waiting list
N01. Shipped. cddumat 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
N03. Shipped. Regland - 1*I2S FIFO Kit, 1*Dual XO Clock Board, 1*S/PDIF Interface Board, 2*BIII adapter
N04. Shipped. AR2 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 2 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 2x Additional BIII adapters PCB, 2x SMT connector package for BIII adapters
N05. Shipped. vertigovh72 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Universal SMT XO Adapters KIT lot of 5
N06. Shipped. sidiropa 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Universal SMT XO Adapters KIT
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
I run out all of the GBII FIFO KIT now. If more the 30 on the new list, I'll start a new run. I keep some empty PCBs in stock this time, so new production would be very quick.
If you want anything other than the FIFO KIT, just sent me the order form, I may still have some stock. For small adapters less than 50g, if it could be posted in a letter, the postage will be much less: Canada $1, USA $2, International $3.
Ian
N07. Canceled.
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
If you want anything other than the FIFO KIT, please just download the order form, fill in it and send it back me, I may still have some stock. For small adapters less than 50g, if it could be posted in a letter, the postage will be much less: Canada $1, USA $2, International $3.
1) cddumat
2) BDL
3) andrea_mori * 3
4) SPWONG
Thanks.
Hi Ian,
I'm very interested in the I2S to PCM converter board, but seems a few people are interested in the NOS way. I'm planning to build several DAC in NOS mode (I own some PCM56, PCM63, AD1862, AD1865 and more), so I need at least 3 more FIFO buffer, but the daughter board is fundamental for me.
I would like to suggest to create a new thread with a different title, including the word "NOS". I believe there are many people interested in NOS DAC today too, but I think they have not read this thread.
Andrea
Originally Posted by andrea_mori
Hi Ian,
While I'm waiting to receive FIFO buffer, just a clarification using it with I2S input from CD-PRO2 and feeding SM5842/PCM63:
- jumper TP48 open, so MCLK is 256*fs, 11.2896 MHz
- jumper TP43 short to ground, left justified to feed SM5842
- jumpers TP41 and TP42 open, I2S 16/32 bit feeding from Philips CD-PRO2
Is that right?
Correct.
Ian
Hi Ian,
just a clarification.
I feed FIFO buffer from CD-PRO I2S signals, CD-PRO outputs 2 words of 24 bit, so SCK is 2.1168. Also I use 11.2896 MHz (256 fs) for FIFO clock.
What kind of I2S signal should I expect at the output of the FIFO buffer (jumper as above)?
Andrea
N07. Canceled.
N17. Finaxe 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N07. Canceled.
N18 Tagheuer 1x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N07. Canceled.
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm
palmito N01. Shipped. cddumat 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
N07. Canceled.
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
anybody know this ocxo 🙂
Ultra Low Phase Noise OCXO - OX-204
–135 dBc/Hz at 10 Hz offset
–175 dBc/Hz at 10 kHz offset
I have just received a quotation for an OCXO from HCD Research Ltd. (distributed from Golledge) with same ultra low phase noise of Vectron OCXO.
The problem is the custom frequency (typically they not produce 11.2896, 12.288 or so), then they quoted a custom part and so the price is high.
I have ordered a sample.
If anyone interested in, we could make a group buy to get lower price.
Also I'm developing a low noise power supply for this OCXO.
Andrea
Andrea
nice 🙂
