variable constant current source?
I would like to build a variable constant current source for experimenting with various stage topologies. I would like something that is variable from say 1ma to more than 10ma maybe as high as 100ma?
I would have suggested LM317 like the others but I think down at 1mA it won't regulate properly. Also as jcx says the bandwidth is somewhat limited - watch out for the parasitic capacitances.
A solution that will encompass 1mA would be an opamp driving the gate of a MOSFET with a resistor to a power rail from its source. -ve input of opamp to source, +ve input of opamp you feed a voltage which defines the current you want. Choose the resistor to suit the current range you require. You need an opamp whose CM input voltage goes down to the -ve supply with an N-channel MOSFET - this makes a current sink. For sourcing, a P-chan MOSFET is called for and the opamp needs to allow CM voltages up to the +ve supply.
A depletion mode mosfet, like the DN2530 or DN2540, will make very good current sources up to about 100mA. See attached drawing.
pb
Oops, you are right about 1mA - I misread the post. But it seems that the 317 can get down to a couple of mA depending on the voltage drop. See below:
-Charlie
any suggestions?
What voltage swing do you need to accommodate?
Kind of important.
Some more:
Isolated? (floating)
Stable?
Accurate? (or you could measure what you dial)
Equivalent source resistance? (Mohms)
Been there, done that.
You can also do a Howland Current Pump with an op-amp and external power device. An advantage of this is that the input can be derived from a reference. (Even a DAC if you so please.) The Howland does have its disadvantages, such as needing twice the load voltage as a supply voltage and sometimes being hard to compensate.
