We all probably agree that fully charged high capacity accumulator's pack is as best as we can provide for an amplifier's power supply. What we try here is to mimic an ideal voltage source, for which accumulator is as closest possible approximation as we can get in reality. Lowest power supply source resistance and instant limitless current capability should be our goal, anything from being cheap. How come closest to that ideal power supply and to still maintain inside reasonable costs is the main question. There's no ideal solution, as always optimization is the key word.
Certainly agree that a good design with psu transformer sounds good. commercially know well some professional big amplifiers, realized with a transformer per channel and large capacitors. I realized that the speech was focused to obtain performance even closer to the dynamic reality. in this case it is necessary to obtain a supply regulation, this independent if analog or smps. I think that on this point we all agree. is different (and I do not agree) that the regulated power supply fast, is not better. this is the point.
speech
in roman languages, ratio and oratio are different words with different meanings.
which is absurd. In greek though, thought, word(vocalisation) and script are all one word: λόγος. Because it is absurd to think one thing, say another and finally write a third thing.
keep that in mind, it will help you not get confused later on 😎
Well IMO it is absurd that thought, word(vocalisation) and script are all one word: λόγος. This because they are all different things.
I started a thread that talks about the geometry of the signals. the conclusion?
those who are not able to understand, they think that I am a charlatan.
then there are those who understand well, then attack me.
the conclusion is real one. amplifier to modulate the current. values of this modulation (according to the dynamics of the source) shall have a right to reconstruct the sound. this can not happen if the supply rails decreases.
this is actually a sub reverse modulation, perfect to change the shape of the signals, right where it defines their speed. (just it is timbre of instument's)
So the power supply must be stabilized, but this requires a high-speed controller. does not make sense to see the ripple, eg. at 100Hz. looks at the rising edge of a square wave also.
I add...that the psu, decides fidelity in reproducing sounds, especially all the sounds that form their characteristic dynamics.
This is not woodo or market convenience, this is science very clear.
AP2,
I am certain that you already know all of this. But it is one of my currently-active areas of interest. So it would have been difficult for me to have not commented.
Please know that I am not quite an expert at any of this (yet). But I have formed a few ideas, which follow, below. For ease of construction, I will just state everything as if it is known to be true. But I am always trying to learn and therefore being shown what is wrong with my thinking is one of the most valuable results I could get, here.
You're close. But the PSU voltage is not the music signal. The PSU current is the music signal.
The capacitors are there to supply current accurately and precisely, when the power transistors lower and raise their channel-resistance in response to the small-signal music control signal.
The power supply voltage variations would be important if PSRR was not good, because the transistor's varying channel-resistance would then not produce a linearly-varying current vs the (base or gate) control signal if the psu voltage that pushes the current was not constant.
Moving on, now also consider the parasitic inductance and resistance of the conductors from the PSU to the power output devices and consider the impedance AS SEEN BY the power pin of the output device and the ground pin of the load (which is the ONLY place it matters). No matter how brilliantly-engineered a PSU or regulator is, i.e. no matter how low its output impedance vs frequency is, it will be partially ruined by anything more than a few centimeters (or less) of wire or PCB trace, especially at the high frequencies that are essential for both closed-loop response speed (with accuracy) and also the precise temporal accuracy of signal-current delivery (visualize the compact-form Fourier components (i.e. with phase angle) of a complex signal and imagine their phase angle accuracy and their "amplitude versus time" accuracy deteriorating as frequency increases. Edges would become blurred and the precise relative timing cues would be lost, degrading the clarity or even the existence of the soundstage imaging, and also the reproduction accuracy of the true nature of each type of sound.
The necessary solution for the highest frequencies must be very-closely-mounted decoupling capacitance, with very-low-impedance connections, right at the points of load for each such device. Next must be one of either a) the PSU or regulator itself, with only a few centimeters (or less) of leads to each power device, OR, b) larger local decoupling capacitances.
The very-local decoupling capacitors would be able to supply the fast transient currents that are needed when a transistor suddenly "opens wider". However, they might often need to be implemented as parallel sets of smaller capacitors, in order to achieve a low-enough impedance to a high-enough frequency. Using multiple [parallel copies of both power and ground rails, from PSU to load, can also be very helpful in maintaining a low-enough impedance, as seen by the load.
If there were no local supply of current and those fast transient currents had to move through the inductances of the power and ground conductors from the power supply or regulator, then they would a) be late arriving, and b) would create relatively-large disturbances in the power rail voltage and the ground rail voltage (the amplitude of which would depend on the time-rate-of-change of the current, not on its amplitude, which means that very "small" currents could create large voltage disturbances, if the currents were fast-changing).
OK. I'll just quit for now.
Tom
None of this is hard until you have a budget. No matter what the budget, and you can build an amp for $100 or $500 or $1,000 as soon as you fix the price then you have to always think in terms making one thing bigger makes something else smaller. More filter caps means yo have to reduce the transformer or the size of the heatsink
This is where real engineers earn their pay. For example anyone could design a bridge over a canyon, simply fill the canyon with concrete. Gets a LOT harder when you want to minimize the cost. Same with amps. It is pretty easy to simply toss in the most expensive parts you can find and build an amp. But let's say the goal was "The best you can build for $250 and the specs are to power a pair of 87dB/W speakers in a 20 foot square room and the use like classical music at 'moderate' volume." Now you have a hard problem and it is not easier if the budget is $500.
A fun project is to model this in Spice. First use a "perfect" voltage source and then run the model again placing a resistor and inductor in series with the perfect power supply and ground return. Choose an inductor and resistor value to match with a one foot length of wire has. The effect that we hear is not really caused so much by the wire alone but is that if combines with the capacitance of the transistor to form a low pass filter.
A qick and easy "fix" is to place a small film by-pass cap directly on the transistor pin. Pretty much like you do when you build with ICs
Do you mean a model kind of like the one at http://www.diyaudio.com/forums/solid-state/216409-power-supply-resevoir-size-37.html#post3117339 ? <grin>
Don't stop Tom,
That was an excellent summary of what this thread is about and it's great to see the PSU gets a well deserved analysis as well, besides the ever prevalent THD numbers haha 🙂
Tom,
thats a lovely analysis.
here's another way of looking at it. If one (in a fit of inspired madness) draws a block diagram representing the overall amplifier transfer function, there will be an input from the power supply - not terribly surprising as thats where all the power comes from.
The trick we pull when analysing smps transfer functions is to casually ignore the supply input - IOW assume it is pure DC and only affects the steady-state solution. we invariably do the same thing with the reference voltage - when we perturb the system of equations we just plain old ignore small-signal variations of Vin & Vref.
Unless something is horribly, horribly wrong, this is a good thing to do with the reference voltage - it really ought not vary. Its often NOT reasonable to ignore the input supply (eg when there is an EMI filter which there always is), but because it makes the analysis so much harder (A buck converter is a 2nd order system; with LC input filter its now a 4th order system), we often cheat - eg using middlebrooks impedance criteria.
We make similar approximations every time we use i = C*dV/dt - its really i = dQ/dt = C*dV/dt + V*dC/dt, but this almost never used (I imagine this would segue nicely into microphonics & electrostatic speakers). there's nothing wrong with approximations, but its wise to know when we are making them - eg if a circuit is physically small wrt wavelength we dont have to use maxwells equations, and can use the LF approximations - Kirchoff, Thevenin etc.
oops, wandered off-topic. Back to the supply rails.
Clearly the existence of PSRR as a concept - and of course curves (PSRR as a number is almost entirely useless - I once discovered the hard way a TL064 has GAIN from the supply to the output at 100kHz) - hint rather strongly that there is a path from the supply to the output.
A cursory examination of output devices show several methods - miller capacitance provides a path into the gate/base (capacitive so HF PSU noise will want to go here), Early voltage, Rds etc. This leads directly to the point Frank eloquently made earlier - that supply disturbances create output disturbances that the amplifier feedback networks must then reject. This is, after all, precisely what gives rise to PSRR.
You and Frank have shown clearly with your numerous simulations that the supply impedance-vs-frequency is very important, regardless of the final answer to the "how-many-farads-per-amp" question. real audio can and does have some exciting transients (Acka Dacka - an inspired choice), and poor HF design of the decoupling network just adds to the work the amplifier has to do.
The great thing about the HF response of the DC Bus networks is that it is essentially FREE. All one needs to do is:
- use multiple smaller caps in parallel (to reduce ESL & ESR)
- have a reasonable portion of them at the amplifier (bypasses the wiring harness inductance)
- do a decent low-inductance layout**
this post was getting a bit long...
**this is not entirely free. the single best way to make a low-inductance layout is to use 2 (or more) layers, and make a parallel-plate "transmission line" - sounds fancy but in practice its dead easy - one layer is 0V the other layer is +Vsupply (or -Vsupply for the other rail). The inductance per unit length of a pair of parallel plates is approximately:
L = u0*separation/width [Henry/m], u0 = 4*pi*10^-7 (R, W & Van Duzer. ignores edge effects)
the separation is the PCB thickness (I use 4-layer PCBs a lot, with a thick double-sided core so the TL-ML1 = ML2-BL separation = 0.113mm), so if you need to reduce L just make it wider. this fits really nicely with using many smaller caps in parallel, and it obeys the "current flows in loops - minimise them" mantra.
If you already have a 2-layer PCB then this really is free. If not - use 2 layers. I do lots of dead-bug prototyping, with a mixture of smt & leaded parts. I use 1.6mm 1-sided PCB for a 0V plane, and have a bunch of 1-layer 0.5mm PCB material (I bought 20x A4 sheets from a supplier for not very much) that I stick on top (often using eg bypass caps to hold it down, sometimes superglue). this works really, really well.
I should also add:
- twist or braid (works great for +Vs/0V/-Vs) the interconnects to reduce the inductance (It also helpfully reduces the emission of, and pickup of, stray magnetic fields). This is especially important for the xfmr-bridge wiring!
- once you split the DC bus caps into rectifier & amp banks, separated by an interconnect, you might as well pop a small R in the interconnect and make a C-R-C filter.
- I would choose the R so that it damps the L-C circuit that is the interconnect L & the amplifier bypass caps. Unless power loss/volt drop is an issue I would heavily damp the network - so it has an RC-type curve (delta = 1) and no overshoot.
this can be done experimentally by using a FET to switch a decent resistive load across the amp decoupling caps, wait a bit & switch it off (fast) while measuring the cap voltage. If you can measure a ringing overshoot, measure its frequency Fring.
2*pi*Fring = 1/sqrt(L_wiring*C_bus) so you can calculate L_wiring if you wish.
this measurement is actually easier to do with high-inductance wiring***
you can then calculate the characteristic impedance of your lumped transmission line (sounds fancy but its just some wiring L and a bunch of caps) Z0 = sqrt(L_ring/C_bus)
And pick R_series >= 2*Z0
(or just pick R_series >= 2/(2*pi*F_ring*C_bus) its the same equation re-arranged)
I was going to say: BUT beware the inductance of WW resistors. But my HP4262A cant even measure the inductance of 0R1,10R,100R 5W ressitors at 10kHz so its << 1uH and can probably be ignored. just saying.....
*** a nice low-inductance braided/twisted wire will have << 1uH ESL, and along with >= 1mF of amplifier bypass cap will have a Z0 that is << 30mOhms - so the wiring resistance itself will probably damp the LC circuit. Fring will be a few kHz, so skin effect actually helps here.
For best AC line ripple rejection make the series R as big as possible (limited only by the volt drop and/or power loss)
I should also add:
Inductance of Single-Layer PCB layouts:
It would be reasonable to assume that if the trace-to-trace separation was equal to the PCB thickness then a single-layer layout will have the same inductance as a 2-layer parallel-plate transmission line (that just sounds so fancy, I love it).
It would also be quite wrong - the single-layer inductance will be quite a bit higher than this.
The reason is simple - AC current flows in the path of LEAST IMPEDANCE. DC current will take the path of least resistance - but above DC this becomes the path of least inductance.
Lets start by ignoring skin effect completely, and just looking at loop inductance.
If the current in the 1-layer traces was evenly distributed then the "loop" responsible for the inductance is the center-to-center distance of the adjacent traces times the trace length. This is usually true at DC and low frequencies.
But its quite different at even moderate AC frequencies. And here's 1 reason why: Loop Inductance.
If we pretend our PCB trace is made of N "filaments" that are 35um square, and pretend these are insulated, we can see that there are a whole bunch of different loops in which the current can flow. Inductance is proportional to loop area = length*separation, and they are all the same length so the inductance is proportional to the separation.
the two closest filaments (call them F1+ & F1- with numbers increasing as we move away from the center-line) have the smallest loop are and hence the smallest L.
There is a slightly larger loop from F1+ to F2- (its 35um further away than F1-), and ditto for F1+_F3- etc. all the way out to F1+_FN-
Then there is F2+_F2-, F2+_F3-....F2+_FN-
this continues all the way to FN+_FN- which has the largest loop.
[this is a perfectly valid, albeit horrific, way to calculate the current distribution. We had to do this in Heavy Current ELectronics, using Mathcad]
the average loop is clearly the center-to-center distance times the length, as asserted at the beginning.
So a 100mm long pair of 5mm wide traces separated by 1.6mm has a loop area of (5mm/2 + 1.6mm + 5mm/2)*100mm = 3.6mm*100mm.
Whereas a pair of 5mm wide traces on opposite sides of a 1.6mm PCB has a loop area of 1.6mm*100mm, which is 3.6/1.6 = 2.25x smaller than the parallel traces.
Note: I should really have added in the Cu thickness here; assume the current is evenly distributed vertically and take the middle of the Cu, giving (35um/2 + 1.6mm + 35um/2) = 1.635mm effective separation, and 1.635mm*100mm loop area. the approximation is only out by 1.635mm/1.6mm = 2.2% so it can be ignored, but for thinner PCBs and/or thicker Cu this might not be true - 4Oz Cu = 0.14mm thick and I have used up to 10Oz Cu = 0.35mm thick. A buddy once showed me a Syncor dc-dc PCB that was IIRC 8-layer 4-Oz Cu -the bare PCB was stupidly heavy, and was about 60% Cu, 40% FR4!!
So the single-layer PCB pretty much always has more loop inductance than the parallel-plane 2-layer PCB. Yeah we can have < 1.6mm trace separation, but it cant get too small, and the trace needs to be wide to carry any decent current.
But wait there's more - the single layer PCb is even worse because of skin effect....
This simple model also shows how current will crowd towards the inner edges - the innermost filaments have the smallest loop hence lowest inductance, so carry the most current, whereas the outermost filaments have the largest inductance and carry the lowest current.
Using the nomenclature N+ = filament no. on one side, N- filament no. on the other side (1 = closest to center) then the loop area = ((N+)*35um/2 + gap + (N-)*35um/2)*length which is:
Loop = [(N+ + N-)*35um/2 + gap]*length
then the innermost loop has N+ = 1, N- = 1 and Loop = [(1 + 1)*35um/2 + gap]*length = [35um + gap]*length
If we define the current flowing through this innermost loop as 1, then the relative current flowing in any arbitrary loop [A+ B-] is:
[(A + B)*35um/2 + gap]*length [(A + B)*35um/2 + gap]
1 x ======================= = ==================
[(1 + 1)*35um/2 + gap]*length [35um + gap]
again this would be fun for someone to play with - you will get a square matrix (assuming both traces same width so N+ = N-, but this will also work for different widths) with 1 in the top LHS (the innermost pair of filaments) and numbers < 1 everywhere else. it will be symmetric, and decrease down the diagonal. The rows represent the filaments on one side, and the columns represent the filaments on the other side.
One could then sum the entire matrix, to get the total relative current, call it S = SUM(all elements). If we then divided the actual current I by this factor S we get the current carried by the innermost filament loop, I_inner = I/S.
The current carried by each filament is just the sum of the relevant row (or column) times I_inner
which is the same as writing I_filament(x) = I_total*SUM(row x)/SUM(entire matrix)
we could then do some cute plots: I_filament(X) vs X gives a plot of current distribution.
later on I'll whack up a MathCAD worksheet for this and post it. Its basically a manual FEA, and is useful because:
1) it shows how the "filament loop" inductance distorts the current distribution, and
2) a manual FEA is actually a pretty good way to solve a bunch of problems if the geometry is easy. I've done it for thermal problems - evenly distributed heat in a wire cooled at either end.
3) it also shows how this approach gets out of hand fast (N^2 loops for N filaments), and why we use FEA programs to do it for us.
(sorry about the long waffly story, I kinda got carried away. Sometimes a simple analogy just doesnt cut it)
Correction/Apology:
Magicbox @ #514 made an astute observation that I really like, but in a fit of inspired stupidity I've been erroneously attributing it to Frank (so many great contributions its easy to get confused. besides I'm thick). Sorry MagicBox, my bad:
At regulatory frequences, the AC output impedance of a MOSFET / Transistor is rather low; any HF signal on the output transistors 'walks' right through the output device, severely destructing PSRR. Luckily the amp must be stable and as such will not have HF AC regulatory swing (if it does, it can't stable out) for audio signals. But to keep that audio signal in perfect shape, you no longer have to view an amp as an LF amp but as an MF/HF amp operating in the 100KHz - 1MHz area.
Edit: Basically the amp has to be fast enough to compensate for its inherent slowdowns in the circuit.
in which he/she (the gender-neutral Xe is useful here, I have no basis for assuming xe is male) points out that the transient response of the amplifier supply directly injects artefacts into the output, which the amp must then correct via the magic of feedback - and this is why the amp BW needs to be higher than expected.
Like so many engineering issues this triggers off a spiral of despair - poor layout => nasty supply transients => higher amplifier BW required => exacerbate effects of poor layout. The really cool thing about this is that the supply rail HF performance can be hugely improved for little or no actual cost, which makes life easier for the amplifier.
That paragraph is worth its weight in spectrum analyzers! mathematical analysis is all well and good, but understanding is the key (and is something maths is all too good at preventing).
Toms detailed description of the correspondence between PSU current & output signal is similarly brilliant. These explanations are IMO clear, cogent and provide crucial insight into the subtleties of amplifier performance.
Add in the awesome simulations, the plethora of excellent questions and responses and voila - this book appears to be writing itself. I cant wait to see how it ends!
Hi, I'm happy that you think in this way 🙂AP2,
Tom
I believe that there is confusion about PSRR, unfortunately lends itself to various types of measurement depends on what you want to see. a good PSRR can completely change the result, as seen in a transient response.
I agree on small capacity additions, on electrolytic capacitors, in the case of bank capacitors, it is better to put a small capacity for each individual.
To obtain the results of a good investigation, decide to proceed with measures true, not by the simulator.
I understand that the only way (economic) in order to obtain good performance, is to use a capacity near the devices. it helps the transient current depends on the capacity can be up to 150ms and after? the sound level of the envelope down. a defect is very common on the "crescendo of classical music," or on the bass strings, eg. with female vocals. (Jazz).
Very poor is chord bass and trumpet with percussion.
it is clear that I am referring to high performance, just those who want a audiophile after spending a lot of money.
After all this, there is also to consider that the market wants new solutions, new dimensions without the weight of the transformer. this is the main reason to look and research new solutions.
I'm ready to put my experience to develop a new circuit, also analog, this can be based on a fast controller that plays in "relative" instead of "absolute". i mean, in a percentage of voltage reported to vInput, in this way it is possible to fix the dissipation. just an idea.
regards
Guys, I applaud you all for your contributions. This has been one of the most interesting threads that I have followed on DIYaudio. You really learn a lot from others and I am hugely impressed by the combined knowledge and experience being delivered.
The only thing needed is a BIG cap(around 1000uF for each Watt power), not a Capacitance multiplier and some smaller condensors paralel because a big cap gives large inductance that must be avoided for high frequencies. There is no issue about this matter.Hi, I'm happy that you think in this way 🙂
regards
- Power Supplies
- Power Supply Resevoir Size
