Paradise phono stage
I just noticed, that in the schematic are some TIP31C and TIP32C in the regulator, but in the Bom it is 1943/5200.
Which ones are right?🙂
D45H11 and D44H11 are the transistors that I used. Most TO220 power transistors will work (do not use darlington’s). If the transistor is capable of handling a few amps at 50 Volts, has an Hfe of 10 or above and a Ft of 10 Mhz or above then it will be fine. Use whichever is available to you.
MJF44H11/MJF44H11
D44H11/D45H11
TIP31C/TIP32C
FJP(F)1943/FJP(F)5200
Best are those that come in a 'Isolated TO220' like this one http://www.onsemi.com/pub_link/Collateral/MJF44H11-D.PDF
