Before you change any more.
Do the mark of the schematic. Calculate the currents through every component.
With burned red LED?
Either heat by being obscured under the FT3 in a very hot 0.8A reg, or its local CCS is a short.
I get off the FT3 replaced the red LED & burned again. I verified all CCS connections & resistors and are all OK.
Is there a resistor in series with that LED? What kind of current does it run? If it runs a few mA then the SK117 CCS it sinks it is healthy, so the Leds maybe dodgy. If it is tens of mA or more then something is shorted and the Led rightfully burns. There is no reason a LED burns out in the Vref regarding general settings, nor it has been reported before. Troubleshoot before we try guess this and that. Use DMM and common sense.
OK, what drop the trimmer shows from end to end when led is a made to a short with a blob of solder on its pads? That is your Vref CCS current. Is it healthy value for 2SK117GR IDSS range or not?
I desoldered the trimmer to see if doesn't work also I measured the resistance near 0R, I trimmed till 838R value as per calculator, I powered & measured 7Vout aprox I used the trimmer but when goes lower than 6,68Vout the red LED lits less & if I goes lower Vout stop to lit
Between 4 & 4,5mA Idss
CCS 800mA
the trimmer shows from end to end when led is a made to a short with a blob of solder on its pads? 4,63-4.64V so I need to change Q103 and Q105 for a stronger Idss like 5V or more?
CCS 800mA
you don't need to be an EE (Electronics Engineer).How I'm not an EE?
Anyone that can do a bit of arithmetic can calculate.
CCS 800mA
Leave the LED shorted, does it work towards 5V? If yes, replace it with a simple diode. Cathode as in LED.
That's what the led did, helped the drift. But with 5.5mA K117 that your drop on 838R gives, there's much total, does not fit. But if it stops at 5.3V with just diode, why not set at where it stops after 15 mins anyway?
With diode I waited 30 minutes or more, Vout measurement was after warm up.
Vref area only 1k trimmer & diode.
- Power Supplies
- SSLV1.1 builds & fairy tales
