Hello Fred,
I have two G300v21 boards, which are similar to the G300D, but wihtout the DSP (as far as I understand). The quality of PCB, parts, and overall assemply seems very good for the price IMO. I've not done intensive listening, but my immediate impression is that they sound really good, powerful and clean, and with very low noise floor.
With regards to the DSP, I think that Sinewave is using SigmaDSP and this seems to require a quite expensive USB device in order to configure the board. But perhaps you know more about this than I do?
Soren
Hi Soren ,
Yes it's SigmaDSP , but expensive is a relative word, it's about 200 Euro. I don't have it but I played around with the software. It was pretty cool. Anyway I am still looking for a 3 (2*) or 6 channel class d amp.
Yes
Check out the DARED DV-6C then ! 😉
Hi Soren ,
Yes
200 Euro is almost the price for a Behringer NU1000DSP, so I consider this expensive. Didn't know that getting to the DSP in a Sinewave DSP amp would be that expensive😱
Real time process of G300DD
Hello all, Someone know if it possible to have (probably by using SigmaStudio or others tools) real time control on crossovers frequency, parametric EQ and volume by a serial communication canal on G300DD ? Migmha
Mickel, we upload block digram picture here, you can real time control it by Sigma Studio software through USBI downloader or you can use one MCU real time control it by I2C with same port.
I2S digital format is 24bit slave mode, DSP is master.
I don't think it can beat the Class D AMPS from (C)SINEWAVE. Looking at this DV-6C AMP it seems also that the Subwoofer channel has different audio signal pass through than the other 5 channels.
So I think this can not work to drive my speakers,
anyway thanks for the reply.
G36d new amp can works at high/mid/low 3way or 2.1CH mode, about sub amp,one tas5630 PBTL support and loader low to 2ohm. DSP and two tas chip osc sync from one active OSC.
I wish I read this sooner as I just ordered a G33D 😡
So the G36D is exactly the same as G33D but with more power?
ok! g36d is high power level version, 3ch and 600w rms power level.
Will it has remote as well? If it has remote it'll be the perfect advanced integrated amp.
Btw, any thoughts of making an amp based on the new TAS5624A? It has the lowest THD of all TI chips and it seems good for a powerful but small digital input only amp if it uses 2 TAS chips inside.
g36d have remote and have Rotary encoder for volume control.
we will try tas new chip later,performance looks good.
And it can use I2S input, and that will be a nice feature when you have MiniDSP platform.
400K G300DD AND 600K G300DD
Our latest version of G300DD have finished , pass all of our test now, paste pictures here .
DSP+TAS5630+Wide Range SMPS all in one
Main class D chip is TAS5630, it can works up to 600Khz PWM frequency,600Khz idle load heat consumption higher than 400Khz, but sound quality excellent.
Named G300DDK6 and G300DDK4
we have compared lots of other chip modules, TAS5630 sound excellent, suit for studio and home audio, high clear bass vigorous.
we have preamp board which support 24bit USB/optical/coaxial input and have I2S slave mode interface .especially it support Asynchronous Sample Rate Converter and this chip have -144dB THD+N and 144dB dynamic range.
It have complete protection function, works more stable.
Good to see that you have finished board! Could you elaborate on the differences between the 600KHz and the 400KHz version?
Thanks.
Thanks.
Thanks.
600kHz board sound better, because sample rate higher, high band frequency have better THD performance, only idle heat loss large than 400kHz ,about 5W-8w.
it have pass all test now, performance well.
600Khz TAS5630
G300DDK6 have finished days ago, some customers have order and test now, we are making case and well pre amp board now, 192kHZ/24BIT USB and Optical and Coaxial and Analog input supports.
Is the 300ddk6 available for order yet and how much is it?
G36 2.1AMP AVAILABLE NEXT MONTH!
Our new version G36 2.1 amp available next month, , it have pass our lab testing now, we are producing first 50pcs manufacturing now.
Features:
1. Ture USB 2.0 interface , 24bit/192kHz in win7 and OS system.
2. High power version :2x200w/4ohm+1x400w/2ohm RMS power.
3. LCD display system.
4. Only one rotary encoder adjust system.
5. all 24bit 192kHz hi-end system.
6. 2 TAS5630B PHD chip inside
7. 110v or 230v auto switchable.
8. auto fan speed system.
if like pls send mail to us, (authlxl@gmail.com) , well price for you, better gifts free for you.
Features:
It uses a fan so the chassis is bigger than the G33? Can you post the pics of the G36? Very interested...
- Vendor's Bazaar
- Tas5630+smps+aluminum case finished!new year coming!
