UCD 25 watts to 1200 watts using 2 mosfets
triell 3200 watts ucd pcb
well i will post pcb after i make it and test it
warm regards
andrew lebon
hi manojtm
greetings how does your yellow core not heat just finished my dclass 3 pairs
90n20 have to use 2 cores together sendust coolmu cores yellow cores dont work
hi andrew
i cannot explain in this thread. practically i made like 1.core temp reduced 2.Efficiency increased 3.DC offset locked to below 25mV 4.reduced EMI 5.MOSFET temp. reduced without heatsink it will work perfectly.now i feel 42V supply 3x MOSFET it produced more than 150W louder and it can handle 14A with cool, I tested 1.6E load mosfet temp only 48deg.c for 15min.
RGDS
Manoj
hi sny
greetings well this triell pcb has not been tested but it sells for 400$
well single sided pcb if well designed is not a problem for dclass amps my IR211O
WITH 3 PAIRS mosfets and zetex gate driver transistors i have no noise issues the ucd
amp has noise issues when placed in a cabinet ucd1200
warm regards
andrew lebon
Set your amplifier gain to 20x and use this diver network:
Start with less than quarter volume and use 4 ohm load.Then go to 1 ohm load.
After that repeat the steps above with less than half volume divider.
That should give you a general ideea of distorsions.
For each of the four cases above run all tests given by the software,before starting any test use calibration feature to have optimum volume.
Software(it is free):
Download. Audio Rightmark
