I found some 6800uf 80v caps with the right dimension and lead space for the 1V20 boards at digikey for about $5. Each. For dual mono that would be 27200uf per rail and 54400uf per channel. This seems like a better route than lowering rail voltage to increase capacitance. (Which I considered) Of course like redjr said one could mount the caps off the board, but I have these nice boards that I just can't let go to waste😀
If you do not need the 80V rating but 63V would be OK, perhaps the new Apexjr caps (35mm) would be an idea. Not sure about the spacing, though.
http://www.diyaudio.com/forums/apex-jr/206439-stock-15-000uf-63v-snap.html
Working voltage from a 45V transformer is @ 64vdc. Thats outside my comfort zone for 63V caps.
Agreed.
Edit: I do not know if these are better than the ones you are considering, but Apexjr also has large 12000uF/80V for $4.50 each.
http://apexjr.com/capacitorsR.html
That's a pretty solid plan for the caps. 🙂
Agreed.
Radial Capacitors
I will have to find out more about those, good find.
Should be more than fine, with over 4x what Stormrider said would be fine.
But with a name like 4x4 that makes sense!
also it's way over double what he called "excessive" so well in keeping with the DIY ethic..
I can't imagine why you'd need more..maybe less is OK even..
I guess I am still somewhat in the 40,000uf per rail state of mind😀
This 380LX223M080A102 Cornell Dubilier Electronics (CDE) | 380LX223M080A102-ND | DigiKey is the highest capacity 80V 35mm diameter 10mm pin spacing cap I've found so far. Unfortunately minimum order quantity is 50 pcs.
From what I've always understood about filter caps... The larger (more ufds) the better and they do no harm, as long as the voltage rating is high enough - and then some - for the PSU rails.Should be more than fine, with over 4x what Stormrider said would be fine.
Some odd 40 yrs ago, I tried building my first 'Tiger' amp from Southwest Technical Products. About ~70wpc. Anyone remember those? 😉 The kit called for some very large caps. IIRC somewhere around 16,000mfd @ about 45v. I was able to source them at the time, but paid dearly, and they looked like small glasses - about 2.5" diameter and 4" high! Never did get that amp working after it fried one pf my KLH bookshelf speakers during a test.
Only harm is the increased inrush current, but an amp with a toroid this big will have a soft start circuit anyway.
The boards have been on sale for awhile now, where are all the build pics? 😀
Is it necessary to have output coil and R49 resistor, if the cables will bi short enough?
thanks
thanks
JoJo,
The guide is beautifully formatted and composed. Hats off!! You have done great credit to Pete's very good design skills........
Congratulations to the DIYaudio crew for producing the Honey Badger!
Hugh
Hugh
JoJo,
Hugh
Hi Hugh,
I wish the guide to be helpful to those who are building the Honey Badger....
Thanks a lot!
Jojo
JoJo,
Hugh
Which guide are you refering to man? I haven't seen a link in the last couple of posts?
Thx
Peter
Thx
Peter
The latest version of the build guides are linked to from the diyAudio store PCB index, or use this direct link to V1.0 of the build guide here. The latest version will always be linked from the store.
Excellent - thank you!
Today I am putting together a BOM for the P-SSSDP-2V20 soft start board from the DIY store. I am having a hard time with C9 and C11. C9 is a class-X 1uf 250V capacitor and C11 is a class-Y .01uf 250V capacitor. Digikey has many different caps that are x y rated but they also have many different material, lead space etc. options. Any advice on narrowing my search down?
C11 would fit either a 15.2mm or a 10.2mm lead space cap. Lead space for C9 can be 27.5mm, 25mm, 20mm or 15mm.
- diyAB Amp - The "Honey Badger"
