hi ravpeet,
with the 3k preset turn to clockwise about 2 o clock position and check with .33/5w resistor.
only one mistake in the pcb that one 18k/2w resistor
above .33/5w resistor.
i am about to start making this M10,and hunting for the componends like IR2117, NJM4580,
Just wanted to ask can i use HER207 insted HER204,205,
HER207 instead HER204,205, yes u can.
what purpose Ur going to make this amp? for business or for yourself.
because i am asking this, the transformer is the main thing. its expensive.
for business u have to make the casing like professional casings, if u can, make it, otherwise its useless, u cant sell. wasting money and time.
for self use its ok.
What is BUSINESS
I don't know about business. as i have said i am not a professional amp maker. its just my hobby. i love music. A LOUD MUSIC. and yes i know the main part is TRANSFORMER. but for me and for my HOBBY, money is no matter.
sir, what hapend with your amp? have u done?
thanks for the schematic nazirdigi,how many watt's in 4 ohms this big amp,is 2 ohm's load possible?
sir, which thermal switch u use in this amp?
and which pcb track has to be cut?
THANK YOU
i use 80degree celcious thermal switch
u check post no 42 and u have to cut pin in relay.
thank you for the reply sir.
- Cheshtap Power Amp
