Let's talk about 'balance'.
Enid Lumley was VERY smart, she had nearly finished her Masters degree (leading to a PhD) in psychology, I think it was UCLA. She had some sort of a 'breakdown' at this time, I think over a broken love affair. I don't know for sure, but I NEVER won an argument with her, she was THAT smart. She had 'golden ears' too, the best that I have ever been close to. To criticize her, when she is now in her grave, is not only pointless but misguided.
When there actually are audible differences, yes. Very basic physics, in fact.
Well, how does physics explain the audible differences between different mains power plugs from the same manufacturer, connected to audio gear, made of different materials?
As for whether those difference are actually audible to me, you are welcomed to come to my home and conduct any blind test you may wish. You can send a representative, if you wish.
People who build gear for their studio copying famous designs. Any design have limitations, and their respective designers know them well. People who copy them don't. That's why problems happen more often than when other people design their own gear, less famous, or even unknown.
Who are you referring to? Is it people you know and can name, or is it just an amorphous statement?
Basic EM theory and power supply design. When you're ready to move beyond an interest in personalities and brands, I can recommend some excellent introductory texts. In the meantime, jneutron has posted quite a few excellent treatments of power feeds, and they're very worth reading.
Point AGND appears to be grounded, so the voltage there will be zero whatever position the switch is in.
With the switch open the +24V and -24V points will be at the stated voltages, because of the 1K resistors which prevent the supply from being totally floating at DC. Close the switch and the voltages will shift - if my arithmetic is correct the '-24' will become -26.1818V and the '+24' will be 21.8181V.
If this shift disrupts the circuit (presumably modelled here by the 1k plus CCS) then that is the result of having a DC supply which is almost floating for DC purposes, yet grounded for AC. I assume there appeared to be a good reason for this unusual design.
If you need balance, why not insist on it by having suitable supply arrangements? It seems perverse to design a circuit which requires exactly balanced supply rails, then run it from a PSU which is guaranteed to provide unbalanced supply rails unless the circuit draws exactly balanced currents. I assume you felt there was a good reason to do it this way.
I think he mentioned not having ground attached to the xfmr as the reason.
With the power supply I am working on which has < 1mOhm @1500 Hz,the difference by closing the switch would be something like 2,2 uV. At DC it would be much less, but have no way to reliably measure.
Problems are lay out and higher frequencies. You can make supply with extremely low output impedance, much lower than realistic pcb-traces would add.
So that also means: where would you connect that LED, to see what the effect on the voltage at different points would be?
vac
