If I want to feed one module with phase-inverted signal, I suppose I need a device or a circuit to split the signal of each channel to feed both modules (one with non-inverted phase, the other with inverted phase). What circuit or device is suitable? Do a simple Y-wiring would do the job (too simple to be be true I guess 😕...)
As the nc400 inputs are true differential inputs, I am assuming you'd be totally OK with a simple Y cable that just has one of the nc400 input pairs reversed.
No problem for bridging two NC400, just in the same way as the UcDxxx modules.
Hello Jan-Peter,
witch diagram is to be used.
Seen this one in on page 8 :
http://www.heliox.nl/download/DatasheetAMP1x50H-8.pdf
And is there a difference for the 4 ohm or 8 speakers?
Jerry
If I order now will I get my amp from the wk21 batch?
Do the amps from this batch still require DC tweaking?
If you order now, delivery is within two weeks. There is no DC tweaking necessary.
Is anybody else still waiting for their wk18 delivery?
Also, can somebody tell me how to open the holes on the 10mm front aluminum plate? I want to open a 19mm hole for the power button, do I use a 19mm drill or a smaller one and work my way up to 19mm?
Yes, I'm. Was told that they would ship out next week after e-mailing them.Is anybody else still waiting for their wk18 delivery?
I would have appreciated if Hypex could have written a specific message about here earlier. That would give them less e-mails to answer as well. Good for both parties.
Do this
I find that increasing the diameter in 2mm steps works quite well with a hand drill
and a vertical drill stand or bench drill also helps but isn't essential
Use nice sharp drills
use a smaller one and work my way up to 19mm
Well, I placed my order week 15, and still haven't gotten a shipping confirmation. 🙁
I received mine last thursday, but I placed the order on 27th february! Already assembled and working, but don't ask me about sound quality (I'm still experimenting).
About the holes, you get a much easier and precise work with a vertical drill (a €50 chinese one is enough) and the right drill bit like this:
http://www.audiophonics.fr/accessories-stainless-hole-saw-c-37_481.html
I tried with a cheaper wood bit too http://www.pianetautensili.it/Public/Prodotti/resize/20105894326748Localmecchialegno.jpg and it worked. It gets ruined easily, but you can sharpen it again with a file.
I ordered for delivery earlier this year but was deferred to wk18.
I have been told my order will be shipped next week.
Metalwork ready waiting
Patience
Patience
Mmm lucky me. I ordered and paid them 6 days before (21st of February). I received my 5 NCore's on the 26th of March and enjoyed them in good working order already from the 1st of April.... I should already start thinking on upgrading my amps.😀
Jan-Peter,
Perhaps you could help with the below question, which as far as I know remains unanswered.
Does the ncore have protection against output device failure, or should a speaker protection board with relays be added?
I don't see this spelled out on the hypex web site.
This question is answered once every 100 pages of this thread or so. The gist of it is, as spelled out in sections 7.2 and 8.1 of the data sheet, use a supply that shuts down when pin 5 of the power connector is pulled low. This pin is pulled low when the NC400 finds the speaker output stuck at a high voltage.
The SMPS600 has this function. If, for reasons of philosophy*, you want to build your own linear supply, add disconnect relays between it and the power amp and make them respond to this line.
DO NOT USE SPEAKER RELAYS. Speakers are inductive little buggers and will sustain an arc across the relay contact long enough for it to weld shut. Speaker relays CAN AND WILL FAIL at the exact moment that you need them.
_____________________
*Reasons of philosophy such as "not believing a switching supply sounds good and therefore concocting a linear contraption and then complaining about the result" 😉
___________________
Hi Sherlock, I have had very good results using a stepless pyramid drill, as used for automobile antennas, and using household spirit as ´drilling oil´. Use high speed and low pressure, and do it in small steps, and measure with the switch continually when you are working.File and sand smoothly afterwards.
Arthur.
Arthur.
I don't think that would work for a 10mm front plateHi Sherlock, I have had very good results using a stepless pyramid drill
(I like pyramid drills too but on thinner sheet)
The 'tank cuttter'/'core drill' type of cutters suggested by antbom work well
- Class D
- Hypex Ncore
