Thats for sure, and no to cats or kids, just shame that the wife doesn't like them
no matter how long you've been together that's always hard to predict, and unwise to ignore: there are more things we can't be changed that will pi$$ them off, "unacceptable" audio gear is an easy sacrifice
I completely agree, thats why I have insisted on a study being built when we have some renovation work carried out, it helped pointing out the advantages of not having all this 'mess' in the main part of the house
Score one for me
Score one for me
Smart man!
and noted that the enclosure for the FE206En was twice the size of the one for the FE126En
That's news to me.
That's news to me.
Hi Scott.
Looking at the width, the fe206 is twice the width of the fe126 version unless I have missed something?
Kirishima is 11.75in wide, internal. Kongo is 5.125in wide, internal. 11.75 / 2 = 5.875, not 5.125.
Note that the cabinets also have different depths, and thus slightly different flare profiles & volumes.
That was my third mistake thanks Scott, it makes the fact that they work so well even more of a fluke.
Mostly it just shows that Olson's original BLH concepts load the driver well enough to alter its specs somewhat. IOW design a horn with the desired in-room response and within reason a wide range of drivers will work acceptably well.
His original 15" 'full-range' corner horn studio monitor's response with loading to 30 Hz when recordings could only get down to a rolled off ~50-60 Hz:
GM
GM
GM
Hi Greg,
That graph is pretty impressive for any era! I wish my speakers measured as well.
In case anyone's wondering, I'm not "that" Olson, I'm the other one.
Best Regards,
TerryO
Best Regards,
TerryO
then there's Lynn - oh a guy could get confused
well actually, Terry, having met two of the remaining members of the Olson audio aristocracy, not so much confused as amused
see you in August
Hi Greg,
Greets!
Absolutely! Pretty amazing for just a single 15" driver. All it would need today is a super tweeter and an appropriate high output impedance amp to drive it.
GM
Mostly it just shows that Olson's original BLH concepts ......
GM
I'm crawling through net for more info ...... I read that Bill Woods sort of promised to make plans and either sell them or share for free (both options OK with me ) ;
is there anything new about that ?
Greets!
GM
Yep, he was a bit good wasn't he? So much for 'progress.'
I read that Bill Woods.....
Greets!
Dunno, I only vaguely recall him either piecing an original back together or building one from data he has and that was many years ago now. Why not just ask him?
GM
Dear all,
Question:
Where (if anywhere) are the simulated low frequency responses of these enclosures?
Apologies, only just noticed this. They'll be on their FH page when it's done, but don't hold your breath -FH3 has been around for the best part of, what, 2 years now & we still haven't had chance to update the site. Time = something neither Dave nor myself have much of at present.
Dear Scott,
I am about to begin building the Haruna design using Fostex FE 166EN. Would like to seek your recommendation on the path of the internal speaker wire. Would it be appropriate to drill a hole in the bottom panel of the driver chamber and seal any gaps with silicone... or .. is it more appropriate to follow the path through the folds?
Do you have any recommendations for the base? Spikes or Granite Slab?
- Full Range
- Spawn Olson/Nagaoka Horns the Next Generation
