Angling of ports and/or drivers?
So, if one were to undertake building an enclosure along the lines of this one, but knew because of placement restrictions that the enclosure would need to be mounted either above or below the planned listening position (possibly as much as 1 1/2'-2' at a twelve foot listening distance), would it be advantageous to cant either the driver, or the ports (or both) to point directly at the desired prime "sweet spot"? Could such modifications result in undesirable side effects in sound reproduction, or is it just a waste of time as the "problem" is not really much of an issue anyway?
A couple of qualifiers...
Let us stipulate these two things for the sake of conversation...
1. The difficulty of construction is not an issue.
2. Angling the entire enclosure is not desirable (aesthetics, read "spouse approval").
being somewhat familiar with the design, the volume and internal length of ports is included in the calculations, so there'd be a little bit more than simply canting the entire cabinet, but I can't 😉 see why not
Dave?
To maintain tuning the only way i can see it down, would be to vertically angle the baffle top to bottom, with the top shallower than the bottom. The bottom would need to increase in depth by at least 36mm to accomodate the unfolding of the L-shaped vent. The other option would be to move the vent to the back firing out the bottom or top (top better for the aspect of where the vent opening is on the inside.
It would then have a significant angle, minimum 67 degrees -- quite a radical angle. Might still need an offset placed on a desk or upside down on a wall.
dave
