Ed Simon has done the latest and best work on OBJECTIVE measurements of resistors and he has brought it to this website. I usually follow his advice on modern resistors, for production of the best audio quality components.
I find it interesting that 12" of wire has a directionality, but you folks never talk about resistor directionality. Capacitors are a different matter since the outside foil is connected to one end.
Late night last night or I would have been up earlier. Went with Sonidos to see a GREAT show at Threadgill's. 😀
Anyway, 12/57. If you have the Audio Anthology series, it's in Volume 4. The pathology was a bit higher than Ed's -140dB wonders. If the resistor is specified properly, VCR is much more important than tempco.
I think I have that, will check when I get home Monday.
jan
We audio designers talk about a lot of things, we just don't discuss them here. Cryoing, laser welding, wire type and purity, for example. I just like to express MY 'experience, strength and hope' here sometimes for interested parties to understand what has worked for ME.
Of course, the feedback resistor was just the FIRST thing that we changed, then we went to REMOVING all the bypass caps and replacing them with a minimal set. Later we changed all the rectifiers to high speed soft recovery types, etc.
Following your advice on another forum, I bought in a local electronic parts store many values of MLT-1 and some MLT-2 resistors which are very cheap.
They are all produced in 1988. I know that they are 5% metal film types,but temperature co. value is not published.I have not yet tried them in my circuits.
What is so special about MLT resistors?
Cheap good common purpose metal-film resistors for audio frequencies. Stable with age, non-magnetic. Low distortion, low noise. Relatively small (compared to VS and especially BLP), so when used of the same size can dissipate more power.
MLT and OMLT, 1/4 to 2 W
-60 to +20 deg C = +/- 1200 ppm
+20 to +125 deg C:
+/- 600 ppm (up to 10K)
+/- 700 ppm (10K to 1M)
+/- 1000 ppm (above 1M)
The MLT resistors are not that bad, for definite groups they have +-50ppm (enclose a picture from the datasheet). But, again, resistive material with almost zero tempco could be of marginal quality for audio applications.
Wow! All standard quality metalized resistors have 50 ppm and we use them at no more than 1/10 rated power .....
Yes, parts keep getting better. Just for fun here is the data on one of the not so good Vishays. Note it even has ninth order distortion!
This particular resistor is still used in some DIY audio projects. Not sure if any commercial offerings use it as I really haven't looked inside many.
SY,
Voltage coefficient was sort of the label for all the stuff for which the source of the problem was not clear. The method of measuring tempco was to determine the resistance at two different temperatures, it did not allow for non-linear tempco curves. The other issue is that there are thermo-electric effects in any termination. If the contacts on each end are not very close to identical then even uniform heating will cause a change. There are some smaller effects, but it seems that thermo and tempco predict almost all of the behavior.
Jan,
-140 db for resistors are actually not as good as some of the circuitry that is available! I think it is possible to get complete amplifiers with distortion below this!
There are two issues that are currently not well understood. One is the influence of noise and the other is the response to waveforms that are not accurately modeled by Fourier series.
ES
Actually Scott it turns out resistors are directional! Every time I drop one it always travels downward! 🙂
ES
(Thanks for the straight line!)
I actually hadn't though of trying the directional tests on resistors, might have a chance next week though.
The major difference between MLT (C2-23, C2-33H) and C2-10 is in constructon of resistive layer. C2-10 in order to work on higher frequencies don't have spiral cuts, their resistance depends on thickness of metal layer. And they are more expensive. The cost that has no value for audio. C2-22 is the same device rated for twice lower power. But it is still the same, when I use routinely MLT-0,5 for 50-100 miliwatt of power instead of 500, and MLT-2 for 100-500 miliwatt.
You listen to music with an infinite number of waveform discontinuities?
When I listen to sounds it is kind of miracle, how without proper thorough analysis I can hear instantly things that are not seen on screens of analyzers. Can you analyze this sounds? Tey sing all around, and it is real stereo stage, with reflections, you can close eyes and hear where they sing, where are trees, where is creek... Amazing! 🙂
http://wavebourn.com/Frogs.wav
what is your point Wavebourn?
cameras aren't any good at scene interpretation either - yet optical distortion measurements, resolution, dynamic range, spectrophotometry, colorimetry are all used to to design better cameras/film/photo print systems
I suspect your clip would be one of the more difficult to AB/X under heavy perceptual compression despite having tossed >80% of the Shannon-Hartley Channel Capacity "Information" - the difference would be easily detected by waveform spectrum analysis despite not being obvious "by ear"
Well everyone, I must be either a 'fool' or an 'idiot' for trying to tell interested parties what I found wrong with the HCA-3500.
After all, it was MY design, at least it had my name and my circuit topology incorporated in it. It was based on my recommended changes to the HCA-2200 Mk2 to make a simpler and more powerful amplifier, and it measured well on my test bench and that of 'Stereophile', so it should be (if I am not a 'fool') perfect, at least in my opinion. Yet it failed with the reviewers and the marketplace. Why? Was anything changed that would 'turn off' the reviewers, such as removing an input IC? NO! Was it more ugly, or plain looking than the amps it replaced? No, not really. Did it do something wrong, like run out of current, have xover distortion, have low slew rate, or even really high odd order harmonic distortion? NO! So what made the HCA-3500 fail with my colleagues and the reviewers when they LISTENED to it?
OK, Jan, it's your turn. Tell me.
John, removing all the bypass caps and replacing ....all of them? or most of them? value changes?
what was the subjective and/or measured effect(s)?
what was the thinking behind going to a "minimal set", why that approach?
Thanks.
Full circle again, maybe time for voicing wires.
SY has warned of the kind of game and the capabilities of the performer a long time ago.
Nevertheless, a resistor placed in this position of that particular circuit should be made out of nothing else but "Zro" to it’s ninth stage.
Specifications of this material have not yet been released, but there is anecdotal evidence that it induces directionality effects.
Enjoy
George
People keep name-dropping Fourier, and hinting that the French gentleman cannot handle their music. Last time I looked, the requirement for a Fourier representation was that the waveform contains nothing worse than a finite number of finite discontinuities. Music is simple by comparison: no discontinuities at all, and band-limited.
Fourier theory seems to be a bit like schoolboy maths: those who are puzzled by it somehow think it is cool to advertise this fact in public.
