you can use it, but i think for better result you should use mur1620 because its reserve recovery time less than mur1660.hi apex sir,
can i use mur1660ct instead mur1620ct for h900v2?
hi apex sir,
Yes, but you can use many other TO220 dual diode also.
hi apex sir,
can i use MUR120 instead bav21 for h900 ?
what should be change in step drive for 120-52-0-52-120 DC supply
hi apex sir,
MUR120 can be use instead BAV21, and no changes for 120-52-0-52-120 DC supply
Thanks a lot for quick reply
with this supply(120-52-0-52-120DC) both rail stepping properly according to signal(gain), but found clipping when voltages start stepping to higher rail.voltages swings between 50 to 80v both rail.
mj777, ask lang for any substitute of MUR1620 and BAV21. Hard to find here in iloilo city.
you can use UF4004.
mj777
ok, clipping found both chanelCan you post pictures?
- 900W H-class PA Amp with Limiter
