learn better
greetings, ...🙂
yes, I am new to using NMOS design, seing as I prefer to use N + P Mos Design, forgive me if this is less wear hearts, ..R u new in this field ?
greetings, ...🙂
Question for Kanawar, would diodes across the gate resistors help flush out the gate charge at higher frequencies?
(I do this on an amplifier designed to produce 80Khz square-waves)
Yes Sir
nice pcb rizqi, good for toner transfer, have more trace gaps, while alex is compact and good too 😀
layout
Thank,... I have scored 4unit, and two more units for each channel using 4mosfet 😱nice pcb rizqi, good for toner transfer, have more trace gaps, while alex is compact and good too 😀
HI Rizqi , Have you made this amp.We in Agra tried it but no success . Can you guide with correct circuit.
regards.
Vedmitra Sharma.
regards.
Vedmitra Sharma.
scheme layout alex is right
n quality of audio is more full in low frequensi
i'm sori if we wrong,... because this project must be carefully.... (kanwar says)
i'll post my amp next time because my cam is bad!!
warm regards
i've make this and corect layout from the last scheme from mr allex...HI Rizqi , Have you made this amp.We in Agra tried it but no success . Can you guide with correct circuit.
regards.
Vedmitra Sharma.
warm regards
HI Rizqi ,
Greetings as you told in post 407 you have successfully made 4 units with 4 mosfet in each channel
can we request that schematic and photos . hope your camera is alright by now.
warm regards
Vedmitra Sharma
warm regards
Vedmitra Sharma
Report
Will someone give a report on the nvmos amp on how it performs,stability,sound?
I'd like to build it but would like know before I make the board and buy the parts.
Looks like this might be a good beer drinking amp to just kick-back in the easy chair and enjoy.
Sam
Sam
- NVMOS amplifier
