For anyone looking to replace the foam surrounds on the ODD-BALL sized Minimus 77 woofer, the current seller of these kits is....
Category 1, Category 2 items in surroundaround-speaker-repair-shop store on eBay!
Look for the posting like this one...
a pair of FOAMS for 4 1/2 - 4 3/4" speaker repair bestQ, inverted roll | eBay
Just an FYI for those who have or would like to own Minimus 77s.
I have some Koss MTM d'appolito-style speakers with foam-rot. I'll have to search hard to find something that will work.
There used to be a store in Maryland, The Speaker Factory. They have no storefront any more, but as a company they may still exist.
AND DONE!
As I took the advise from another user on this forum(can't remember the name...sry)...I glued the outer first making sure the surround was as centered as I could make it(I used a digital caliper set to ensure it was very close on the outside. Using tiny clamps, glue the surround and wait 24hrs. Then the cone. I didn't use shims to keep it centered. I just let gravity hold it where it naturally sit. Then, carefully glue the surround to the cone (making small adjustments before the glue cured) with a small brush. Then wait some more. After all said and done...it was time to test. Voice coil didn't rub!!! I was in business. Tested at higher volume and it worked perfectly. Now, they sit on my shelf, sounding great once more. Hope it all turns out well for you!
Quick update.....new link
Small 5" Surrounds Spkr Repair Bestq Inverted Roll Minimus 77 Prev 4 1 2 4 3 4 | eBay
And....the new link is....
A Pair of 4 3 4" 5" Speaker Foam Surrounds for Speaker Repair Bestq | eBay
- Radioshack MINIMUS 77 refoam Kit
