bass speaker help
and it works
I will call it The Antiressonator 😀
... it was an effort to eliminate resonances from the cabinet materials....
good point 😉
built a crappy proto, and now being punished with this rework job :clown:
front is sorted, and decided to look at the cabinet back
first step, to make the woofer hole slightly bigger, and improve edge shape
big heavy woofer, and I wanted to support the chassis, taking some load off the screws
working inside a limited space, new circle router tool needed
and then some work with file and sandpaper 😱😀
need to consider speaker cable connector
noticed a speakon which also accept a 1/4" jack
but I dont know much about this
btw, theres a really nasty ressonance when talking into cabinet
but if inserting a small bucket into the hole, it disappears
which also ought to happen with the woofer mounted
need to work on front baffle design now
despite 40mm thickness, the rather big backplate appeared a bit too ressonant
bracing added
front baffle design is more or less sorted
