F5 or F5turbo?
why not? say 30W pr device.
4 devices x 30W = 120W
20C above ambient = 20/120=0.16C/W
sink temp 45C ish
I do dig the sink size problem but Papa said they sound beter at hi bias
I got TO 220 pulling 40 W since last August with no problems
so one can have 4 at 30 W or 3 at 40 W.
If sink size is not enoug stick a fan on it
If you do not want a fan buid 2 and go balanced or do not build the thing
Same sayd that one end up with 10K worth of amplifier and I can only agree with it and keep this in mind.
Why one need a 100W amplifier I got tumy tumping Bass with 3 V out?
May reason is that I am only Human also gredy Boyz I not going to complain about litle (biG) snags.
Or to put it another way do you want a Car with 300 Hp do not nag about price of petroll.
For the "normal" F5 with 2 output devices the recomended heatsink is 0.3W/C per channel, so my very simple calculation was that for using 4 output devices I would need half to have the same bias per device. I could use a bit less bias and go with .2W/C heatsinks though.
€ 120.00 + IVA trasporto incluso
XXXXXXXXXXXXXXXXXXXXXXXXXXX
> Speetabili signori.
> Per favore quotatemi il prezzo per:
> 2 unita del profilo 5314 coun un altezza di 165 mm
> Mi servono spianati e anodizzati in nero.
Ø mi servira la spedizione per Lingilterra.
Quote from Gorini SRL
2 profile 5314 165mm tall as in drawing milled flatt and anodised black
120euros including P&P to the UK
if you like the 400 tall 60 Euros each + P&P if you like 600 wide that wuld be
24 inches in pints they just weld 2 togheter for 36 they weld 3 and cut to any lenght you like.
Best of hall they got the potato chip curly fins
If you need help talking with Marzia just ask
> Speetabili signori.
That's a great price, I got a quote from fisher of 150euros each heatisnk of 400x200x80, without shipping. must see into those italian ones.
Just to give you flavour of what a CPU fan can do
I was matching a batch of FQP19N20 yesterday
I am using a CPU fan to keep the cooper plate at 50C
I am matching them at 2A 24V and taking VGS reading when the sink settles at 50 C
My maths tell me 48W the fan runs at about 30 %
Sam more pictures here
http://www.diyaudio.com/forums/pass-labs/188608-my-f5-2.html#post2852558
Not showing off just triing to give same back I ma gonna put smiley there as you forgot.😀
This Aple vine is ok fermentation has been cut to shorth and it taste like decent Verduzzo my bipinng head is going to explode tomorow.
Know good vine you bet...
