figure it out
I had opportunity to see folder with no less than ~190 possible design permutations .....
now you see why I'm not building or even drawing anything , since BAF
I am feeling with you......
Or ZM is changing to serius man or just fooling as always
I think he got a Sirius man at the sea coast.....
If my memory serves me well it doesn´t have a balanced input, so the input stage might not be a differential amplifier.
Is this a type of differential? See attached.
Yes, of course.
But it´s not from Nelson.
P.S.
Otherwise it might have a balanced input.
I´m quite curious about the F6.
As there are no compementary R100 devices available, there appears the question what solution Nelson had found.
A current source in the output stage without a differential input, so maybe using a different kind of feedback?
But a complementary input stage like F5 doesn´t seem make to much sense, while using a current source.
There were some solutions for push pull amplifiers using only n channell devices....
I am thinking more of a JLH style input with a JFET and perhaps a single ended output...
I remember that in a thread comparing F6 to L'amp, Nelson said that it s not a current source design.
And in another one he said that in case we need more power, the F5T is the way. So my guess is that we will see a SET design
Could I please be excused with some more greediness and ask if we have any updates?
- New F6 diy coming soon ?
