New F6 diy coming soon ?
I have the pc boards, and when I have a little time I will stuff up the
official copy and write the article.
It is comparable in power to the rest of the FW amplifiers, uses the
R100 power Jfets (but can also use regular Mosfets) and is unique in
a couple of ways.
I'm only going to make 10, and there is no intention to sell them, so it's
strictly DIY.
If you want more juice, then the F5 Turbo is probably what
you want.
excellent!! i can feel a GB for the R100A coming on, have you tested these parts Nelson? X? unfortunately anything that wont accept balanced inputs is kinda out for me except for novelty reasons as my main rig only has balanced outs
i'll echo the thanks and amazement of above!!
a couple of ways.
strictly DIY.
you want.
Well give us the boost and let us loose ................ 🙂
you're all loose ...... all the time .......
Awesome, it sounds like 2012 is shaping up to be a really big Pass DIY year.
Should I fear this is a harbinger of the the world's end?
Interesting point..... According to the Mayan calendar, in 2012 the world will come to pass.
Now I'm wondering if they meant "pass", as in, decease/end/terminate, die.......
Or did they mean "Pass", as in Mentor, Poppa, Learned One, Nelson
Oh.....the mysteries of life.......
So, I suppose more news on the F6 will be released soon?
The F5 turbo sound like fun, but I'm looking forward to hearing Jets in the power stage.
I'm almost done the Zen 9 and wonder if there is any potential family resemblance between the F6 ad F5?
I´m quite curious about the F6.
If my memory serves me well it doesn´t have a balanced input, so the input stage might not be a differential amplifier.
As there are no compementary R100 devices available, there appears the question what solution Nelson had found.
A current source in the output stage without a differential input, so maybe using a different kind of feedback?
But a complementary input stage like F5 doesn´t seem make to much sense, while using a current source.
There were some solutions for push pull amplifiers using only n channell devices....
