280mm x 50mm
how'd the length get up to 280mm ? i thought it was 250mm ?
11 + inches kinda kills it for reasonably priced heat sinks .
cheers Woody
cheers Woody
Woody,
You will really, really need large heatsinks for this.
The size was based around the 300mm heatsinks that are commonly used.
Bear in mind you have 8 MOSFETS in class A so they are dissipating alot of heat.
Where did you get the idea about 250mm?
Andy
Are you guys doing balanced builds with the 4 boards or 2 amps?
Yes, 4 amp boards for F5TURBOX and 4 or 6 psu boards.
The wonderful psu boards I can also use for other projects.
cheers Woody
you gonna need 16 inchs to have enuff room for everything ....
bi-amping with F5 turbo? we now know the reason for global warming
Winter setup ....... instead of fire wood ...
One possible cost effective heatsink option I was thinking of
is something like 10 wide X any length quoted ones from likes of heatsinkusa.com.
Since it is better the pins run vertical rather than horizontal, I'm considering getting 4 pieces of 10 inch wide 12inch high and bolt 2 together for each left and right side. That would make 20inch long 12 inch high per each side of stereo. Eventually I will build another one and turn them in monoblocks with higher bias current or balanced version.
-John
-John
-John
Similar idea ..... going for 12 in height not sure how much class-a bias as yet , 50 watt / ch sounds about where i wanna be !!!
http://www.heatsinkusa.com/products/8.460"-Wide-x-12"-Long-Heatsink.html
4 of these per amp .... yes fan too ...
hehehe a lot more fun
i use aleph2 monoblocks in wintertime and are now building F5 for summer time and a aleph30
Blimey,
Massive cases!!!
Have you considered forced air cooling?
Case will be cooled , hate getting off the gas when in boost ....
going for height
None of my business, but with a 0.30" base plate and 1" fins, that heatsink doesn't deliver beyond a height of 7 inches.
(y'all know it's girth that matters)
The HeatsinkUSA E007 has 2.5 inch fin height, 3/8 inch baseplate.
But I agree that increasing the length (parallel direction of fins) of the heatsink doesn't help much beyond a certain point.
Well it's 16 inchs of girth and 12 inch looks good and fit a lot of caps and transformers .........
-John
Here is a simulation using the HeatsinkUSA E007 - 20" wide x 12" long, 48 fins, 180 W dissipation. With natural convection, the C/W is still too high.
I agree, unless you use a fan.20 x12 heatsink is not enuff......
Here is a simulation using a single HeatsinkUSA E007 12 inches long with an air velocity of .679 m/s. The table show results with other air velocities.
- F5 Turbo Circuit Boards
