F5 Turbo Circuit Boards
how'd the length get up to 280mm ? i thought it was 250mm ?
11 + inches kinda kills it for reasonably priced heat sinks .
cheers Woody
Woody,
You will really, really need large heatsinks for this.
The size was based around the 300mm heatsinks that are commonly used.
Bear in mind you have 8 MOSFETS in class A so they are dissipating alot of heat.
Where did you get the idea about 250mm?
Andy
One possible cost effective heatsink option I was thinking of
is something like 10 wide X any length quoted ones from likes of heatsinkusa.com.
Since it is better the pins run vertical rather than horizontal, I'm considering getting 4 pieces of 10 inch wide 12inch high and bolt 2 together for each left and right side. That would make 20inch long 12 inch high per each side of stereo. Eventually I will build another one and turn them in monoblocks with higher bias current or balanced version.
-John
-John
Similar idea ..... going for 12 in height not sure how much class-a bias as yet , 50 watt / ch sounds about where i wanna be !!!
http://www.heatsinkusa.com/products/8.460"-Wide-x-12"-Long-Heatsink.html
4 of these per amp .... yes fan too ...
-John
Here is a simulation using the HeatsinkUSA E007 - 20" wide x 12" long, 48 fins, 180 W dissipation. With natural convection, the C/W is still too high.
