800 Watt MOSFET Amplifier Module
Here is my latest amplifier module hot off the press!
Contact me for more info:
It is available now for purchase from my online store!
Cheers
Anthony
Is this scheme and lay outnya ..... mr? if anyone in the share .........
Cheers
Anthony
* Featuring Balanced XLR and Single Ended RCA input stage.
* Can be power from separate power supplies for the Input and Driver Stage
* Very low noise and distortion
* Unconditionally Stable
* Extra Heavy Duty three ounce copper printed circuit boards.
* Gold Immersion copper track plating
* Rugged high performance Toshiba MOSFET output stage.
* RoHs Compliant
* Very easy to install and get going
* Sound quality and reliability rivaling the best in the world
Preliminary Specifications
* 500 Watts RMS continuous sine wave into 8 Ω
* 800 Watts RMS continuous sine wave into 4 Ω
* 1200 Watts RMS short term sine wave into 2 Ω
* The HPA-nxV800 is 2 Ω Stable
* Biased into Class A/B
* Power Bandwidth 3.5hz to 250khz -3dB
* Slew Rate = 90 volts / microsecond approximately
* Dampening Factor At 100hz 8Ω = 1300
* Dampening Factor At 1khz 8Ω = 915
* Dampening Factor At 10khz 8Ω = 248
* RCA Single ended Input impedance 20kΩ
* XLR Balanced Input Impedance 40kΩ
* Differential Input Gain = 33.8dB
* Single Ended Input Gain = 28.1dB
* THD+N - Typically 0.003%
* Recommended Voltage Supply +-98 volts DC
* Operational Supply Voltage Range +-20v dc to +-105 volts DC
* PSU Power Transformer secondary windings 65vac (1200VA)
* Printed Circuit Board Dimensions 325mm x 50mm
* Minimum Recommended Conrad heat sink MF35-100 to MF35-151.5
dear sir pls cote me the cost
Hello,
I'm interested in your 800 watts amp. however, as an amplifier enthusiast, i would want to build it with myself. So, can you help me by posting or sending the complete circuit with complete details and also biasing, through my email arvin_ksa2000@yahoo.com? I will be thankful to you...
More power!!
Arvin
Hi Alvin
Sorry mate I only sell modules 🙂
Cheers
Anthony
Aussie Amplifiers
Hi Anthony,
Your nxv800 sure looks the treat 🙂
I can see on your website that you have introduced R2 versions of the nxV300 and 500.
Are the changes that these R2´s are based on, in any way similar to some of the attributes of the nxV800 such as possibility for a dedicated VAS supply and less nfb?
Some comments from you on what that can be expected from these R2´s in terms of technical attributes and of course most important how they sound compared to your other offerings would be highly appreciated.
For reference I have a pair of nxV200 signature, so I have first hand knowledge of how they perform in my system.
Also, I have noticed on other amps that routing the speaker return either back to the amp board or directly back to the ground reference between the supply caps can have a significant impact on the audible performance.
- what is your recommendation for getting most out of your amps (speaker return back through the boards or directly back to PS ground ref?)
I´d guess that making the current flow back trough the ground plane on an amp can affect the performance somehow -especially regarding the working conditions of the nfb loop(s)...
best,
Juhl,
carefully trace out the route that the speaker current follows from smoothing capacitor through to the amplifier, through the various traces and output components of the amplifier and then the final part of that route to the speaker Hot Terminal.
Where on that route is the point that passes over or very nearby the Main Audio Ground?
Now take your speaker return route to exactly follow the flow current route twisting the speaker return lead with the Hot flow lead for a long as is possible, till you reach that Main Audio Ground.
Now examine the loop area formed by the speaker flow and return wiring. Is it minimised? That is what you need and it reduces the effects of high current flow in the speaker cables on the low level circuits that pass nearby.
Hi Andrew,
Thanks for your guidance -its highly appreciated!
My main audio ground is the starground point between the supply caps. The point where the supply leads leave the supply caps is thereby also the point with shortest distance to the main audio ground (if I understood that correctly).
The way I read you, the point for me is to make the speaker return follow the hot speaker lead back to Main Audio ground. If this is correct, it seems that I have two possible extremes; being either to have the hot lead as short as possible (directly from board hot terminal to enclosure terminal) -making the return lead following back to the board and then back to Main Audio Ground. Or Having the return lead as short as possible (directly from enclosure terminal back to Main Audio Ground between the supply caps) -making the hot speaker lead following back to MAG and then to hot terminal on amp board.
The third possibility would of course be to direct both hot and return lead back to the amp board, but to the (speaker return terminal) on the amp and from there making the hot go back to hot terminal on the board and the return thereby connect with the Main Audio Ground through the boards ground lead.
-Any recommendations on which of those two opposites (or routing return back through the board to MAG) that should be best?
(My own guess would be that the amp will be affected by the electrical parameters of the wiring meaning that routing back to amp will provide a better L/C ratio for the amp to chew on)
BTW, I have no noise issues at all so I´m not trying to deal with that. It´s more about getting the best possible sound from the amp and based on experiences with other amps, choosing to direct the speaker return current through the boards (speaker return terminal) opposed to directly back to star ground between the supply caps can have significant influence on the sound. Unfortunately not only for the better in either case...
best,
Hi Anthony,
best,
Hi Juhleren
The R2 nxv300 and nxV500 are based on the nxV800 module and all of these
modules now share the option of having a dedicated VAS-Input stage power supply and they also share the nested feedback loop.
Regarding the Speaker Ground point, the best option I would suggest would be to connect the Ground point at the speaker GND on the main amp board,
This provides a single GND return back to the main power supply ground, rather than the two return grounds back to the power supply GND.
The signal grounds on the main amp board are isolated via a 10 ohm resistor
from the main ground plane and are connected from this resistor directly
to the main power ground point on the amp board.
So they would not be influenced by the power supply GND currents.
Cheers
Anthony
Thanks Anthony,
I will try that 🙂
Those R2 revisions sure sound interesting. I guess they also differ in sound then. Any words on how they can be expected to do so?
Are VAS supplies to be the same or slightly higher in voltage than the output supplies, then?
And are there any plans on implementing nested nfb and optional VAS supplies in future nxV200 revisions?
Thanks Anthony,
I will try that 🙂
With the R2s you can expect sharper focus on the imaging and sound stage.
The nxV200 Signature already has the nested feedback.
For the VAS supplies it is best to have at least 5 volts higher that the main output stage.
Cheers
Anthony
