Suggestions for an tube-amp with KT88
I thint the ST120 looks a bit too rough, you can see the pcb and the coloured caps. has you got some other suggestions?
With some creative wiring and a cover for the transformers in the back, you will have a nice and easy to maintain amp. There are builds with the capacitors rewired so you can move them to the underside leaving the gain tubes for show.
I am looking at the Bob Latino ST-70 running with KT-88 tubes as a project. The transformers will handle it and I can go from triode to pentode mode at a flip of the switch. Biasing will also breast too.
Read up on the mods and reviews -- you might be surprised.
